):v2.3.0
systemd service, but testing on CLI
ubuntu 20 focal fossa
systemctl start caddy
root * /home/diaspora/diaspora/public
reverse_proxy localhost:3000
I’m trying to convert this older caddy config to the newer version, and am running into issues with the transparent and except functions.
I get the same result whether I run through a tcp port or a unix socket
# absolutely minimal configuration. "Works on my machine"
# adds no-referrer policy for some added privacy.
diaspora.example.com {
header / {
Referrer-Policy "no-referrer"
root /home/diaspora/diaspora/public
proxy / unix:/home/diaspora/diaspora/tmp/diaspora.sock {
except /assets /uploads
When I run this, I get a connection on port 80, but none of my graphics are showing up. I can provide access to the public site so that it can be seen. It does the same thing whether I go through the public URL or the local IP
caddy just fails to start.
i’ve tried researching the two comments under proxy, but i’ve been unable to find an answer, hence I"m here
