systemd unit
Ubuntu 20.04.1
systemctl start caddy
User=www-data
Group=www-data
email email@example.com
experimental_http3
(basics) {
encode zstd gzip
rewrite /api /api/
(static) {
@static {
file
path *.ico *.css *.js *.gif *.jpg *.jpeg *.png *.svg *.woff *.woff2 *.json *.webp
header @static Cache-Control max-age=2678400
(security) {
X-Frame-Options SAMEORIGIN
X-XSS-Protection 1; mode=block
(ws) {
@websockets {
header Connection Upgrade
header Upgrade websocket
http://wllhvn.wg {
import basics
import static
rewrite / /index.html
rewrite * /wllhvn{path}
reverse_proxy http://localhost:9000 {
header_up Host {host}
header_up Connection ""
dial_timeout 5m
handle /api/* {
reverse_proxy 10.3.0.175
handle_errors {
rewrite * /index.html
http://wllhvn.wg:6566 {
import ws
reverse_proxy @websockets http://10.3.0.175:6001 {
header_up Connection Upgrade
header_up Upgrade websocket
My Caddy is reverse proxy to local S3 serving static files. When I receive 404, S3 returns XML with error and status code 404. So I want to handle these errors and redirect user to index.html
No errors
I just have no idea what to do. I googled a lot but found no documentation about reverse proxy to S3 404 handling.
