v2.2.1
Using standard systemd startup script.
AWS Amazon Linux 2 on Lightsail nano instance
No commands. Purely systemd.
# caddy.service
# for your installation.
# command or use the caddy-api.service file instead.
ExecStart=/usr/bin/caddy run --environ --config /var/lib/caddy/Caddyfile
ExecReload=/usr/bin/caddy reload --config /var/lib/caddy/Caddyfile
(server) :443 {
reverse_proxy /files/* http://127.0.0.1:10080 {
flush_interval -1
header_up Connection Upgrade
header_up Upgrade Websocket
root * /var/lib/caddy/wwwroot
level DEBUG
output file /var/lib/caddy/access.log
I’ve been using tusd lately and trying to use Caddy to terminate SSL and act as a reverse proxy. The https part is working fine and the reverse proxy works to a degree but seems to fail under load. I’ve attempted to convert the reverse proxy settings in this nginx config and so far have got this:
flush_interval -1
Like I said, it seems to work, but not under load where I start getting “read tcp: i/o timeout” errors in the tusd logs when it tries to send a response back. I believe the data is streamed from the client so the connection could be getting dropped?
Bypassing Caddy and going direct to tusd works as expected.
tusd[1127]: [tusd] 2020/12/16 10:37:32 event=“ResponseOutgoing” status=“500” method=“PATCH” path=“snip” error=“read tcp: i/o timeout” requestId=""
The config above.
