I am trying to expose a http server to my friend by reverse proxying:
Server <-> My PC <-> My friend
192.168.2.116 10.xx.xx.1 10.xx.xx.2
After running caddy rerverse-proxy
on my PC, the reverse proxyed address respond empty.
2023/06/21 14:37:18.609 WARN admin admin endpoint disabled
2023/06/21 14:37:18.609 INFO tls.cache.maintenance started background certificate maintenance {"cache": "0xc000025ab0"}
2023/06/21 14:37:18.609 WARN http automatic HTTPS is completely disabled for server {"server_name": "proxy"}
2023/06/21 14:37:18.610 INFO tls cleaning storage unit {"description": "FileStorage:C:\\Users\\sheey\\AppData\\Roaming\\Caddy"}
2023/06/21 14:37:18.611 INFO http.log server running {"name": "proxy", "protocols": ["h1", "h2", "h3"]}
Caddy proxying http://0.0.0.0:1234 -> 192.168.2.116:80
2023/06/21 14:37:18.612 INFO tls finished cleaning storage units
scoop install caddy
Windows 11, x86_64.
caddy reverse-proxy --from http://0.0.0.0:1234 --to http://192.168.2.116 --debug
The server (which also behind caddy):
$ curl -v http://192.168.2.116
* Trying 192.168.2.116:80...
* Connected to 192.168.2.116 (192.168.2.116) port 80 (#0)
> GET / HTTP/1.1
> Host: 192.168.2.116
> User-Agent: curl/8.0.1
< HTTP/1.1 200 OK
< Content-Type: text/html; charset=utf-8
< Date: Wed, 21 Jun 2023 14:49:12 GMT
< Etag: "ggf25z5fp79j0"
< Server: Caddy
< Vary: Accept-Encoding
< X-Powered-By: Next.js
< Transfer-Encoding: chunked
<!DOCTYPE html><html l... (html body)
caddy proxying:
$ curl -v http://localhost:1234
* Trying 127.0.0.1:1234...
* Connected to localhost (127.0.0.1) port 1234 (#0)
> GET / HTTP/1.1
> Host: localhost:1234
< HTTP/1.1 200 OK
< Server: Caddy
< Date: Wed, 21 Jun 2023 14:50:09 GMT
< Content-Length: 0
