V2
I’m planning on running Caddy in an Amazon Lightsail Container (Docker).
AWS Lightsail Container using the Caddy docker image
This is the part I want to know if I can modify. The Lightsail container service gives me very few options to modify the content of a container, however I can run a one liner startup script. When I deploy the container, would it work to use the following (from the quick setup guide) in a start.sh script? I’ll have no terminal or ssh access, so need something simple.
caddy reverse-proxy --from :2016 --to my.aws.endpoint.stuff:9000
