I already tried without transparent and without websocket, still the same result. Btw, the target of the reverse proxy is not something like website-b.example.com: in the browser the address will always stays at example.com.
Yep, right: the address will not change to the WEBSITE-B’s address. I used the wrong terminology.
I tried to replicate the problem with the simplest possible configuration, but it worked exactly as expected.
~/Projects/test
➜ mkdir website1 website2
~/Projects/test
➜ echo "I'm website 1!" > website1/index.txt
~/Projects/test
➜ echo "I'm website 2!" > website2/index.txt
~/Projects/test
➜ cat Caddyfile
:8080 {
proxy / localhost:8081
proxy /rb localhost:8082 {
without /rb
:8081 {
root website1
:8082 {
root website2
~/Projects/test
➜ caddy -version
v1.0.4
~/Projects/test
➜ curl localhost:8080
I'm website 1!
~/Projects/test
➜ curl localhost:8080/rb
I'm website 2!
This is very strange indeed. I replicate your simple example and it works. But when i try with this Caddyfile, it doesn’t…
example.com:443 {
header / Strict-Transport-Security "max-age=31536000"
proxy / https://INTERNAL-IP-A {
websocket
insecure_skip_verify
proxy /rp INTERNAL-IP-B {
without /rp
Maybe external webservers manage those type of requests in a different way…
