systemd
c. Service file:
Type=notify
# domain name.
admin off
email "frank@somedomain.com"
git.kumro.io {
reverse_proxy http://trinity:3000
I set up a reverse proxy from a ramnode VPS to my home lab which is connected via tailscale. From the VPS running Caddy, I can curl the address listed in the error message and have gitea reply properly. When I access the site from outside the VPS, through Caddy, I get a 502 and the error is posted below.
Jan 16 00:43:34 matrix.kumro.io caddy[4536]: {"level":"error","ts":1642293814.5707703,"logger":"http.log.error","msg":"dial tcp 100.90.111.16:3000: connect: permission denied","request":{"remote_addr":"69.207.23.160:37854","proto":"HTTP/2.0","method":"GET","host":"git.kumro.io","uri":"/","headers":{"Dnt":["1"],"Te":["trailers"],"Accept":["text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,*/*;q=0.8"],"Accept-Language":["en-US,en;q=0.5"],"Cookie":["i_like_gitea=9701c0690ce5e9e7; gitea_awesome=frank; gitea_incredible=e7fde55c658f8472ff0115b0e3ca4e8a7a35a3112e8f0cdd93693b7f62df313c62; lang=en-US; _csrf=Cf9co1yhhbNaa_e1B3z4IRRMKdk6MTY0MjI4MzYzOTU3MzcwNzM3OQ"],"Sec-Fetch-Dest":["document"],"Sec-Gpc":["1"],"Sec-Fetch-User":["?1"],"User-Agent":["Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:96.0) Gecko/20100101 Firefox/96.0"],"Accept-Encoding":["gzip, deflate, br"],"Upgrade-Insecure-Requests":["1"],"Sec-Fetch-Mode":["navigate"],"Sec-Fetch-Site":["none"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","proto_mutual":true,"server_name":"git.kumro.io"}},"duration":0.005676763,"status":502,"err_id":"j1bm253zu","err_trace":"reverseproxy.statusError (reverseproxy.go:857)"}
Curl / wget / ping the server in my home lab from the VPS running Caddy, it works. This was working before I rebooted the VPS and added a port forward for port 2222. Tailscale is running and I can reach the machine in my home lab from the VPS, I tried to rule out tailscale.
From the VPS running Caddy.
curl -v -s trinity:3000
* Rebuilt URL to: trinity:3000/
* Trying 100.90.111.16...
* TCP_NODELAY set
* Connected to trinity (100.90.111.16) port 3000 (#0)
> GET / HTTP/1.1
> Host: trinity:3000
> User-Agent: curl/7.61.1
< HTTP/1.1 200 OK
< Content-Type: text/html; charset=UTF-8
< Set-Cookie: i_like_gitea=0cb48a79a13cf3aa; Path=/; HttpOnly; SameSite=Lax
< Set-Cookie: _csrf=tQVk0tBR5Ifo_iulp-jAoRuoxV46MTY0MjI5MzU1ODQzMDM5OTc1Mw; Path=/; Expires=Mon, 17 Jan 2022 00:39:18 GMT; HttpOnly; SameSite=Lax
< Set-Cookie: macaron_flash=; Path=/; Max-Age=0; HttpOnly; SameSite=Lax
< X-Frame-Options: SAMEORIGIN
< Date: Sun, 16 Jan 2022 00:39:18 GMT
< Transfer-Encoding: chunked
