docker-compose.yml requests “latest”
Docker Compose
OSX > Vagrant > Virtualbox > Ubuntu (hashicorp/bionic64) > Docker-Compose
$ lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 18.04.3 LTS
Release: 18.04
Codename: bionic
$ docker --version
Docker version 20.10.7, build f0df350
$ docker-compose --version
docker-compose version 1.24.1, build 4667896b
docker-compose up -d
# docker-compose.yml
version: "3.7"
image: caddy
- $PWD/site:/srv
- caddy_data:/data
- caddy_config:/config
jellyfin:
restart: always
image: jellyfin/jellyfin:latest
user: 1000:1000 # should be owner of volumes
network_mode: "host"
restart: "unless-stopped"
- /srv/jellyfin/config:/config
- /srv/jellyfin/cache:/cache
- /media/Music:/media
caddy_data:
caddy_config:
email somebody@somewhere.com
#debug
x.duckdns.org {
reverse_proxy 192.168.1.x:8096
unable to get a successful reverse proxy going.
stage server output: acme-staging-v02
debug is off. there seemed to be enough base errors to start troubleshooting
$ docker-compose logs -f --tail 500 caddy
Attaching to vagrant_caddy_1
caddy_1 | {"level":"info","ts":1625883647.1926813,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":"caddyfile"}
caddy_1 | {"level":"info","ts":1625883647.2015343,"logger":"admin","msg":"admin endpoint started","address":"tcp/localhost:2019","enforce_origin":false,"origins":["localhost:2019","[::1]:2019","127.0.0.1:2019"]}
caddy_1 | {"level":"info","ts":1625883647.2149746,"logger":"http","msg":"server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS","server_name":"srv0","https_port":443}
caddy_1 | {"level":"info","ts":1625883647.215157,"logger":"http","msg":"enabling automatic HTTP->HTTPS redirects","server_name":"srv0"}
caddy_1 | {"level":"info","ts":1625883647.2157936,"logger":"http","msg":"enabling automatic TLS certificate management","domains":["x.duckdns.org"]}
caddy_1 | {"level":"info","ts":1625883647.2162442,"msg":"autosaved config (load with --resume flag)","file":"/config/caddy/autosave.json"}
caddy_1 | {"level":"info","ts":1625883647.216494,"msg":"serving initial configuration"}
caddy_1 | {"level":"info","ts":1625883647.2166073,"logger":"tls","msg":"cleaning storage unit","description":"FileStorage:/data/caddy"}
caddy_1 | {"level":"info","ts":1625883647.2173343,"logger":"tls","msg":"finished cleaning storage units"}
caddy_1 | {"level":"info","ts":1625883647.217439,"logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0xc0000d96c0"}
caddy_1 | {"level":"info","ts":1625883647.2215476,"logger":"tls.obtain","msg":"acquiring lock","identifier":"x.duckdns.org"}
caddy_1 | {"level":"info","ts":1625883647.232989,"logger":"tls.obtain","msg":"lock acquired","identifier":"x.duckdns.org"}
caddy_1 | {"level":"info","ts":1625883647.3102748,"logger":"tls.issuance.acme","msg":"waiting on internal rate limiter","identifiers":["x.duckdns.org"],"ca":"https://acme-staging-v02.api.letsencrypt.org/directory","account":"caddy@gearslip.com"}
caddy_1 | {"level":"info","ts":1625883647.3105738,"logger":"tls.issuance.acme","msg":"done waiting on internal rate limiter","identifiers":["x.duckdns.org"],"ca":"https://acme-staging-v02.api.letsencrypt.org/directory","account":"caddy@gearslip.com"}
caddy_1 | {"level":"info","ts":1625883648.4414392,"logger":"tls.issuance.acme.acme_client","msg":"trying to solve challenge","identifier":"x.duckdns.org","challenge_type":"tls-alpn-01","ca":"https://acme-staging-v02.api.letsencrypt.org/directory"}
caddy_1 | {"level":"error","ts":1625883659.2972374,"logger":"tls.issuance.acme.acme_client","msg":"challenge failed","identifier":"x.duckdns.org","challenge_type":"tls-alpn-01","status_code":400,"problem_type":"urn:ietf:params:acme:error:connection","error":"Timeout during connect (likely firewall problem)"}
caddy_1 | {"level":"error","ts":1625883659.2974432,"logger":"tls.issuance.acme.acme_client","msg":"validating authorization","identifier":"x.duckdns.org","error":"authorization failed: HTTP 400 urn:ietf:params:acme:error:connection - Timeout during connect (likely firewall problem)","order":"https://acme-staging-v02.api.letsencrypt.org/acme/order/20209807/97837002","attempt":1,"max_attempts":3}
caddy_1 | {"level":"info","ts":1625883660.4364653,"logger":"tls.issuance.acme.acme_client","msg":"trying to solve challenge","identifier":"x.duckdns.org","challenge_type":"http-01","ca":"https://acme-staging-v02.api.letsencrypt.org/directory"}
caddy_1 | {"level":"error","ts":1625883670.7935524,"logger":"tls.issuance.acme.acme_client","msg":"challenge failed","identifier":"x.duckdns.org","challenge_type":"http-01","status_code":400,"problem_type":"urn:ietf:params:acme:error:connection","error":"Fetching http://x.duckdns.org/.well-known/acme-challenge/CnLC-Q7bLEmU8_P-AeQVTXYiJom9bCDGOL-idvdtaVw: Timeout during connect (likely firewall problem)"}
caddy_1 | {"level":"error","ts":1625883670.7937672,"logger":"tls.issuance.acme.acme_client","msg":"validating authorization","identifier":"x.duckdns.org","error":"authorization failed: HTTP 400 urn:ietf:params:acme:error:connection - Fetching http://x.duckdns.org/.well-known/acme-challenge/CnLC-Q7bLEmU8_P-AeQVTXYiJom9bCDGOL-idvdtaVw: Timeout during connect (likely firewall problem)","order":"https://acme-staging-v02.api.letsencrypt.org/acme/order/20209807/97837123","attempt":2,"max_attempts":3}
caddy_1 | {"level":"error","ts":1625883672.3087118,"logger":"tls.obtain","msg":"could not get certificate from issuer","identifier":"x.duckdns.org","issuer":"acme-staging-v02.api.letsencrypt.org-directory","error":"[x.duckdns.org] solving challenges: x.duckdns.org: no solvers available for remaining challenges (configured=[http-01 tls-alpn-01] offered=[http-01 dns-01 tls-alpn-01] remaining=[dns-01]) (order=https://acme-staging-v02.api.letsencrypt.org/acme/order/20209807/97837257) (ca=https://acme-staging-v02.api.letsencrypt.org/directory)"}
caddy_1 | {"level":"error","ts":1625883672.3090603,"logger":"tls.obtain","msg":"will retry","error":"[x.duckdns.org] Obtain: [x.duckdns.org] solving challenges: x.duckdns.org: no solvers available for remaining challenges (configured=[http-01 tls-alpn-01] offered=[http-01 dns-01 tls-alpn-01] remaining=[dns-01]) (order=https://acme-staging-v02.api.letsencrypt.org/acme/order/20209807/97837257) (ca=https://acme-staging-v02.api.letsencrypt.org/directory)","attempt":1,"retrying_in":60,"elapsed":25.075907144,"max_duration":2592000}
caddy_1 | {"level":"info","ts":1625883733.0823252,"logger":"tls.issuance.acme.acme_client","msg":"trying to solve challenge","identifier":"x.duckdns.org","challenge_type":"http-01","ca":"https://acme-staging-v02.api.letsencrypt.org/directory"}
caddy_1 | {"level":"error","ts":1625883743.3607962,"logger":"tls.issuance.acme.acme_client","msg":"challenge failed","identifier":"x.duckdns.org","challenge_type":"http-01","status_code":400,"problem_type":"urn:ietf:params:acme:error:connection","error":"Fetching http://x.duckdns.org/.well-known/acme-challenge/nvyV1A_sY8L_Yt3rC8DjeMUfbNi8ZePD_a_2vbkZhJM: Timeout during connect (likely firewall problem)"}
caddy_1 | {"level":"error","ts":1625883743.3610396,"logger":"tls.issuance.acme.acme_client","msg":"validating authorization","identifier":"x.duckdns.org","error":"authorization failed: HTTP 400 urn:ietf:params:acme:error:connection - Fetching http://x.duckdns.org/.well-known/acme-challenge/nvyV1A_sY8L_Yt3rC8DjeMUfbNi8ZePD_a_2vbkZhJM: Timeout during connect (likely firewall problem)","order":"https://acme-staging-v02.api.letsencrypt.org/acme/order/20209807/97837891","attempt":1,"max_attempts":3}
caddy_1 | {"level":"info","ts":1625883744.499879,"logger":"tls.issuance.acme.acme_client","msg":"trying to solve challenge","identifier":"x.duckdns.org","challenge_type":"tls-alpn-01","ca":"https://acme-staging-v02.api.letsencrypt.org/directory"}
caddy_1 | {"level":"error","ts":1625883755.6387696,"logger":"tls.issuance.acme.acme_client","msg":"challenge failed","identifier":"x.duckdns.org","challenge_type":"tls-alpn-01","status_code":400,"problem_type":"urn:ietf:params:acme:error:connection","error":"Timeout during connect (likely firewall problem)"}
caddy_1 | {"level":"error","ts":1625883755.6389778,"logger":"tls.issuance.acme.acme_client","msg":"validating authorization","identifier":"x.duckdns.org","error":"authorization failed: HTTP 400 urn:ietf:params:acme:error:connection - Timeout during connect (likely firewall problem)","order":"https://acme-staging-v02.api.letsencrypt.org/acme/order/20209807/97838025","attempt":2,"max_attempts":3}
caddy_1 | {"level":"error","ts":1625883756.8411572,"logger":"tls.obtain","msg":"could not get certificate from issuer","identifier":"x.duckdns.org","issuer":"acme-staging-v02.api.letsencrypt.org-directory","error":"[x.duckdns.org] solving challenges: x.duckdns.org: no solvers available for remaining challenges (configured=[http-01 tls-alpn-01] offered=[http-01 dns-01 tls-alpn-01] remaining=[dns-01]) (order=https://acme-staging-v02.api.letsencrypt.org/acme/order/20209807/97838164) (ca=https://acme-staging-v02.api.letsencrypt.org/directory)"}
caddy_1 | {"level":"error","ts":1625883756.8414094,"logger":"tls.obtain","msg":"will retry","error":"[x.duckdns.org] Obtain: [x.duckdns.org] solving challenges: x.duckdns.org: no solvers available for remaining challenges (configured=[http-01 tls-alpn-01] offered=[http-01 dns-01 tls-alpn-01] remaining=[dns-01]) (order=https://acme-staging-v02.api.letsencrypt.org/acme/order/20209807/97838164) (ca=https://acme-staging-v02.api.letsencrypt.org/directory)","attempt":2,"retrying_in":120,"elapsed":109.608256304,"max_duration":2592000}
The exact same caddy + duckdns + jellyfin reverse proxy setup runs fine on a raspberry pi (rpi).
Decided to copy (edit: meant “recreate”. did not just copy the instance over) it over to VM on a desktop machine on the same LAN.
The rpi instance is shutdown to avoid potential conflicts.
Router port redirect and Caddyfile reverse proxy are both pointing at the correct IP address.
All the familiar ports seem to be open.
[another mechine on same LAN] $ nc -zvw3 192.168.1.x 80 443 8096 2019
Connection to 192.168.1.x 80 port [tcp/http] succeeded!
Connection to 192.168.1.x 443 port [tcp/https] succeeded!
Connection to 192.168.1.x 8096 port [tcp/*] succeeded!
nc: connect to 192.168.1.x port 2019 (tcp) failed: Connection refused
Port 2019, listed in the logs above, is closed, but since it’s also closed on the working rpi instance, so I’m assuming (there’s that word) that’s expected.
Browsing the the VM’s jellyfin instance via IP address from other machines on the LAN works fine.
Curl tests:
# http - success:
$ curl -v http://x.duckdns.org
* Connected to x.duckdns.org (x.x.x.x) port 80 (#0)
* Connection #0 to host x.duckdns.org left intact
# https. - error:
$ curl -v https://x.duckdns.org
* connect to x.x.x.x port 443 failed: Connection refused
* Failed to connect to x.duckdns.org port 443: Connection refused
* Closing connection 0
curl: (7) Failed to connect to x.duckdns.org port 443: Connection refused
Not recalling anything else at the moment.
I did a lot searches with various combinations of keywords (ie: caddy reverse proxy vagrant virtualbox, etc), but nothing really bore fruit.
Since the same setup on the rpi runs fine, I’m guessing it’s has something to do with the vagrant + virtualbox + docker combo.
Any thoughts or clues greatly appreciated. Thanks!
