2.0.0
Kubernetes (K3S)
K3S on Ubuntu
caddy run --config=/etc/caddy/Caddyfile.json
apiVersion: apps/v1
kind: Deployment
metadata:
namespace: default
labels:
app: reverse-proxy
tier: proxy
spec:
replicas: 2
revisionHistoryLimit: 1
strategy:
type: RollingUpdate
rollingUpdate:
maxSurge: 2
maxUnavailable: 0
selector:
matchLabels:
app: reverse-proxy
tier: proxy
template:
metadata:
labels:
app: reverse-proxy
tier: proxy
spec:
- name: caddy-data
persistentVolumeClaim:
claimName: caddy
- name: caddy-config
configMap:
containers:
- name: caddy
image: caddy:2.0.0
imagePullPolicy: Always
command: ["caddy", "run"]
args:
- --config=/etc/caddy/Caddyfile.json
volumeMounts:
- name: caddy-data
mountPath: /data
mountPath: /etc/caddy/Caddyfile.json
subPath: Caddyfile.json
resources:
requests:
memory: "100Mi"
cpu: "60m"
limits:
memory: "150Mi"
cpu: "90m"
livenessProbe:
tcpSocket:
port: caddy
initialDelaySeconds: 5
periodSeconds: 10
readinessProbe:
tcpSocket:
port: caddy
initialDelaySeconds: 15
periodSeconds: 20
- containerPort: 80
- containerPort: 443
"apps": {
"http": {
"servers": {
"srv0": {
"automatic_https": {
"disable": true
"listen": [
":80"
"routes": [
"match": [
"host": [
"caddy.myserver.io"
"handle": [
"handler": "reverse_proxy",
"transport": {
"http": {
"protocol": "http",
"tls": {}
"upstreams": [
"dial": "icanhazip.com:443"
"terminal": false
I’m trying to set a transport to reverse proxy an HTTP → HTTPS request. The transport says I’m missing a protocol? Which I have.
If I remove the transport I get an error on the end server that I’m speaking HTTP to an HTTPS server. If I remove the transport and talk HTTP it works.
run: loading initial config: loading new config: loading http app module: provision http: server srv0: setting up route handlers: route 0: loading handler modules: position 0: loading module 'reverse_proxy': provision http.handlers.reverse_proxy: loading transport: module name not specified with key 'protocol' in map[http:map[protocol:http tls:map[]]]
Verified that HTTP reverse proxying works without any issue. Tried seeing if the protocol
needed to be something like “https” instead of "http.
