Reverse proxy for ssh tunnel
Hi, I want to use Caddy as a reverse proxy on example.com for my server (localserver) that I run at home behind a always changing ipv6 adress.
As a first try I used
autossh -M 0 -f -o ConnectTimeout=10 -o ServerAliveInterval=60 -o ServerAliveCountMax=2 -i /home/user/.ssh/id_ed25519 -N -R 8888:localserver:8000 example.com
where the localserver was reachable in the internet on example.com:8888. In the next step I want to utilize Caddy to have it reachable on example.com and ssl encrypted. My current Caddyfile is not working as intented. Can someone help?
no entries
ubuntu 22.04 verison package sources
Linux ubuntu 6.8.0-49-generic #49-Ubuntu SMP PREEMPT_DYNAMIC x86_64 x86_64 x86_64 GNU/Linux
 sudo caddy run --config /etc/caddy/Caddyfile
c. Error Messages
2024/11/25 09:50:07.353 ERROR   http.log.error  dial tcp [ipv6-IP]:8888: connect: connection refused      {"request": {"remote_ip": "ipv4", "remote_port": "53918", "proto": "HTTP/2.0", "method": "GET", "host": "example.com", "uri": "/", "headers": {"Sec-Fetch-Mode": ["navigate"], "Accept": ["text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8"], "Accept-Language": ["de,en-US;q=0.7,en;q=0.3"], "Accept-Encoding": ["gzip, deflate, br, zstd"], "Dnt": ["1"], "Cookie": [], "Upgrade-Insecure-Requests": ["1"], "Sec-Fetch-Dest": ["document"], "Sec-Fetch-Site": ["none"], "User-Agent": ["Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:132.0) Gecko/20100101 Firefox/132.0"], "Priority": ["u=0, i"], "Te": ["trailers"], "Sec-Fetch-User": ["?1"]}, "tls": {"resumed": false, "version": 772, "cipher_suite": 4865, "proto": "h2", "server_name": "example.com"}}, "duration": 0.015068564, "status": 502, "err_id": "1uqd76vsu", "err_trace": "reverseproxy.statusError (reverseproxy.go:1272)"}
2024/11/25 09:50:07.442 ERROR   http.log.error  dial tcp [ipv6-IP]:8888: connect: connection refused      {"request": {"remote_ip": "ipv4", "remote_port": "53918", "proto": "HTTP/2.0", "method": "GET", "host": "example.com", "uri": "/favicon.ico", "headers": {"Sec-Fetch-Dest": ["image"], "User-Agent": ["Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:132.0) Gecko/20100101 Firefox/132.0"], "Accept": ["image/avif,image/webp,image/png,image/svg+xml,image/*;q=0.8,*/*;q=0.5"], "Referer": ["https://example.com/"], "Cookie": [], "Sec-Fetch-Mode": ["no-cors"], "Sec-Fetch-Site": ["same-origin"], "Priority": ["u=6"], "Te": ["trailers"], "Accept-Language": ["de,en-US;q=0.7,en;q=0.3"], "Accept-Encoding": ["gzip, deflate, br, zstd"], "Dnt": ["1"]}, "tls": {"resumed": false, "version": 772, "cipher_suite": 4865, "proto": "h2", "server_name": "example.com"}}, "duration": 0.000841018, "status": 502, "err_id": "du61zvrt2", "err_trace": "reverseproxy.statusError (reverseproxy.go:1272)"}
example.com {
        reverse_proxy example.com:8888
That’s a really old version. Please use our official installation instructions: Install — Caddy Documentation
You shouldn’t run Caddy directly like this. Run it as a systemd service: Keep Caddy Running — Caddy Documentation
If you have a tunnel, do you mean to do reverse_proxy localhost:8888 instead, which would then pass through the tunnel listening on port 8888?
Hi Francis,
thanks for your quick answer. I updated Caddy to: v2.8.4 h1:q3pe0wpBj1OcHFZ3n/1nl4V4bxBrYoSoab7rL9BMYNk= and it runs as a systemd service now.
I tried changing example.com to localhost, still not the expected behaviour.
{"level":"error","ts":1732538610.5072064,"logger":"http.log.access.log0","msg":"handled request","request":{"remote_ip":"1.2.3.4","remote_port":"9455","client_ip":"1.2.3.4","proto":"HTTP/2.0","method":"GET","host":"example.ceom","uri":"/","headers":{"Dnt":["1"],"Cookie":["REDACTED"],"Upgrade-Insecure-Requests":["1"],"Sec-Fetch-Dest":["document"],"Sec-Fetch-Mode":["navigate"],"Sec-Fetch-Site":["none"],"User-Agent":["Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:132.0) Gecko/20100101 Firefox/132.0"],"Accept":["text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8"],"Accept-Language":["de,en-US;q=0.7,en;q=0.3"],"Accept-Encoding":["gzip, deflate, br, zstd"],"Sec-Fetch-User":["?1"],"Priority":["u=0, i"],"Te":["trailers"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"example.ceom"}},"bytes_read":0,"user_id":"","duration":0.000329726,"size":0,"status":502,"resp_headers":{"Server":["Caddy"],"Alt-Svc":["h3=\":443\"; ma=2592000"]}}
{"level":"info","ts":1732538611.9577575,"logger":"http.log.access.log0","msg":"handled request","request":{"remote_ip":"1.2.3.4","remote_port":"9455","client_ip":"1.2.3.4","proto":"HTTP/2.0","method":"GET","host":"example.ceom","uri":"/favicon.ico","headers":{"Accept-Language":["de,en-US;q=0.7,en;q=0.3"],"Accept-Encoding":["gzip, deflate, br, zstd"],"Dnt":["1"],"Sec-Fetch-Dest":["image"],"User-Agent":["Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:132.0) Gecko/20100101 Firefox/132.0"],"Referer":["https://example.ceom/"],"Cookie":["REDACTED"],"Sec-Fetch-Mode":["no-cors"],"Sec-Fetch-Site":["same-origin"],"Priority":["u=6"],"Te":["trailers"],"Accept":["image/avif,image/webp,image/png,image/svg+xml,image/*;q=0.8,*/*;q=0.5"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"example.ceom"}},"bytes_read":0,"user_id":"","duration":0.000062918,"size":0,"status":0,"resp_headers":{"Server":["Caddy"],"Alt-Svc":["h3=\":443\"; ma=2592000"]}}```
I think you changed the wrong one. I mean the reverse_proxy one, not your site address.
Hi Francis,
sadyl I changed the right one to localhost, so no easy fix…
I made some changes to my config file in the meanwhile. For a start, serving a static html file in /var/www/ works with the standard config. I added some lines for logging.
        root * /var/www
                output file /var/log/caddy/log.log {
                        roll_size 10mb
                        roll_keep 20
                        roll_keep_for 720h
So the basics work. Can I add a reverse proxy to example.com/p with this lines?
        reverse_proxy /p/* localhost:8888
If I add them, I still get a 404 error. I’m starting to think it is an issue with firewall or system. I had the same configuration running with the same localserver, ssh tunnel and a other public linux vps running apache…
Could you please:
  • Add debug to your global options
  • Run curl -vL against your website, with the intent of being routed to the reverse proxy (example.com/p/test or as appropriate)
  • Post the output of curl as well as the logs produced by Caddy for that request
Done:
$ usr@srv curl -vL example.com/p
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
  0     0    0     0    0     0      0      0 --:--:-- --:--:-- --:--:--     0* Host example.com:80 was resolved.
* IPv6: 2a01:111:111:300::1
* IPv4: 12.122.12.12
*   Trying [2a01:111:111:300::1]:80...
* Connected to example.com (2a01:111:111:300::1) port 80
> GET /p HTTP/1.1
> Host: example.com
> User-Agent: curl/8.5.0
< Connection: close
< Location: https://example.com/p
< Server: Caddy
< Date: Tue, 26 Nov 2024 08:56:32 GMT
< Content-Length: 0
* Closing connection
* Issue another request to this URL: 'https://example.com/p'
* Host example.com:443 was resolved.
*   Trying [2a01:111:111:300::1]:443...
* Connected to example.com (2a01:111:111:300::1) port 443
} [5 bytes data]
} [512 bytes data]
*  CApath: /etc/ssl/certs
{ [5 bytes data]
{ [122 bytes data]
{ [15 bytes data]
{ [2021 bytes data]
{ [78 bytes data]
{ [36 bytes data]
} [1 bytes data]
} [36 bytes data]
* SSL connection using TLSv1.3 / TLS_AES_128_GCM_SHA256 / X25519 / id-ecPublicKey
* ALPN: server accepted h2
*  subject: CN=example.com
*  start date: Nov 24 21:38:28 2024 GMT
*  expire date: Feb 22 21:38:27 2025 GMT
*  subjectAltName: host "example.com" matched cert's "example.com"
*  issuer: C=US; O=Let's Encrypt; CN=E5
*   Certificate level 0: Public key type EC/prime256v1 (256/128 Bits/secBits), signed using ecdsa-with-SHA384
*   Certificate level 1: Public key type EC/secp384r1 (384/192 Bits/secBits), signed using sha256WithRSAEncryption
*   Certificate level 2: Public key type RSA (4096/152 Bits/secBits), signed using sha256WithRSAEncryption
{ [5 bytes data]
{ [122 bytes data]
* using HTTP/2
* [HTTP/2] [1] OPENED stream for https://example.com/p
* [HTTP/2] [1] [:method: GET]
* [HTTP/2] [1] [:authority: example.com]
* [HTTP/2] [1] [:path: /p]
* [HTTP/2] [1] [user-agent: curl/8.5.0]
* [HTTP/2] [1] [accept: */*]
} [5 bytes data]
> GET /p HTTP/2
> Host: example.com
{ [5 bytes data]
< HTTP/2 404
< server: Caddy
< content-length: 0
< date: Tue, 26 Nov 2024 08:56:32 GMT
* Connection #1 to host example.com left intact
You made a request to example.com/p, but you configured your reverse proxy for /p/*:
/p doesn’t match /p/*, so that request isn’t being sent to the reverse_proxy and is instead being handled by the file_server, which explains the 404.
Try making a request to /p/ or /p/foo instead if you want the request to be handled by the reverse_proxy.
Thanks for the hints, Matthew. Now it is working!
example.com {
        root * /var/www
        reverse_proxy /p/ localhost:8888
                        roll_size 10mb
                        roll_keep 20
                        roll_keep_for 720h
curl says:
usr@srv:~$ curl -vL example.com/p/
* IPv6: 2a01:111:111:111::1
*   Trying [2a01:111:111:111::1]:80...
* Connected to example.com (2a01:111:111:111::1) port 80
> GET /p/ HTTP/1.1
> Host: example.com
< Connection: close
< Location: https://example.com/p/
< Server: Caddy
< Date: Tue, 26 Nov 2024 13:15:14 GMT
< Content-Length: 0
* Issue another request to this URL: 'https://example.com/p/'
*   Trying [2a01:111:111:111::1]:443...
* Connected to example.com (2a01:111:111:111::1) port 443
* using HTTP/2
* [HTTP/2] [1] OPENED stream for https://example.com/p/
* [HTTP/2] [1] [:path: /p/]
> GET /p/ HTTP/2
> Host: example.com
< HTTP/2 200
< accept-ranges: bytes
< date: Tue, 26 Nov 2024 13:15:14 GMT
< last-modified: Sun, 23 Jun 2024 19:30:38 GMT
< server: Caddy
< vary: Accept-Encoding
<!DOCTYPE html>
<html lang="en">
  <head>
    <meta charset="utf-8" />
    <link rel="icon" href="/photoview-logo.svg" type="image/svg+xml" />
    <link rel="apple-touch-icon" href="/logo192.png" />
    <meta name="viewport" content="width=device-width, initial-scale=1" />
    <meta name="theme-color" content="#000000" />
    <link rel="manifest" href="/manifest.json" />
    <meta name="apple-mobile-web-app-title" content="Photoview" />
    <meta name="apple-mobile-web-app-capable" content="yes" />
    <meta name="apple-mobile-web-app-status-bar-style" content="white" />
    <script type="module" crossorigin src="/assets/index.8d4c57fa.js"></script>
    <link rel="stylesheet" href="/assets/index.0ac106ed.css">
  </head>
  <body>
    <noscript>You need to enable JavaScript to run Photoview.</noscript>
    <div id="root"></div>
  </body>
</html>
but only with example.com/p/ and not with example.com/p
I thought in context of urls the behavioru should be the same?
One new issue is the relaive paths of files are not found. The browser says:
Loading of modules from  "https:/example.com/assets/index.8d4c57fa.js" is blocked because of MIME types.
How can I point in to the url including the /p/?
"https:/example.com/p/assets/index.8d4c57fa.js"
This will now match only EXACTLY requests for /p/ and will not match requests for /p/foo or /p/bar, nor will it match /p, as you note.
Not at all. Path matchers are exact, literal matchers. Refer to the documentation:
Path matching is an exact match by default, not a prefix match. You must append a * for a fast prefix match. Note that /foo* will match /foo and /foo/ as well as /foobar; you might actually want /foo/* instead.
https://caddyserver.com/docs/caddyfile/matchers#path-matchers
/p/* would match the path /p/assets/index.8d4c57fa.js.
Thanks all for your help, I set it up using subdomains and it works flawlessly. Should have gone directly to this…
