1. Output of caddy version
Ubuntu 22.04 LTS (GNU/Linux 5.15.0-1019-aws x86_64
sudo caddy start
example.com {
handle /api/* {
reverse_proxy localhost:3000
handle /auth/* {
root * /home/ubuntu/source/liverepo/dist/production-chart-front-end
try_files {path} {path}/ /index.html
This is an Angular application with a node backend. The issue I face is when I attempt to navigate to the reverse proxy for the back in, the path isn’t matched when there are query parameters. If I go to https://example.com/auth/code?response_type=code&… caddy directs to the Angular application, but if I go to https://example.com/auth/code the backend application receives the request.
I know I’m not supposed to redact the domain, but it isn’t mine to choose to disclose. There are also 6 query parameters that are passed to this route in case that matters.
This issue only occurs in production, in local dev the requests also use a proxy and they work.
Sep 19 13:16:52 ip-172-31-41-174 systemd[1]: Starting Caddy...
Sep 19 13:16:53 ip-172-31-41-174 caddy[438]: caddy.HomeDir=/var/lib/caddy
Sep 19 13:16:53 ip-172-31-41-174 caddy[438]: caddy.AppDataDir=/var/lib/caddy/.local/share/caddy
Sep 19 13:16:53 ip-172-31-41-174 caddy[438]: caddy.AppConfigDir=/var/lib/caddy/.config/caddy
Sep 19 13:16:53 ip-172-31-41-174 caddy[438]: caddy.ConfigAutosavePath=/var/lib/caddy/.config/caddy/autosave.json
Sep 19 13:16:53 ip-172-31-41-174 caddy[438]: caddy.Version=v2.5.2 h1:eCJdLyEyAGzuQTa5Mh3gETnYWDClo1LjtQm2q9RNZrs=
Sep 19 13:16:53 ip-172-31-41-174 caddy[438]: runtime.GOOS=linux
Sep 19 13:16:53 ip-172-31-41-174 caddy[438]: runtime.GOARCH=amd64
Sep 19 13:16:53 ip-172-31-41-174 caddy[438]: runtime.Compiler=gc
Sep 19 13:16:53 ip-172-31-41-174 caddy[438]: runtime.NumCPU=1
Sep 19 13:16:53 ip-172-31-41-174 caddy[438]: runtime.GOMAXPROCS=1
Sep 19 13:16:53 ip-172-31-41-174 caddy[438]: runtime.Version=go1.18.3
Sep 19 13:16:53 ip-172-31-41-174 caddy[438]: os.Getwd=/
Sep 19 13:16:53 ip-172-31-41-174 caddy[438]: LANG=C.UTF-8
Sep 19 13:16:53 ip-172-31-41-174 caddy[438]: PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/snap/bin
Sep 19 13:16:53 ip-172-31-41-174 caddy[438]: NOTIFY_SOCKET=/run/systemd/notify
Sep 19 13:16:53 ip-172-31-41-174 caddy[438]: HOME=/var/lib/caddy
Sep 19 13:16:53 ip-172-31-41-174 caddy[438]: LOGNAME=caddy
Sep 19 13:16:53 ip-172-31-41-174 caddy[438]: USER=caddy
Sep 19 13:16:53 ip-172-31-41-174 caddy[438]: INVOCATION_ID=eea81cf308264aa9ac423b1713f6bc72
Sep 19 13:16:53 ip-172-31-41-174 caddy[438]: JOURNAL_STREAM=8:17097
Sep 19 13:16:53 ip-172-31-41-174 caddy[438]: SYSTEMD_EXEC_PID=438
Sep 19 13:16:53 ip-172-31-41-174 caddy[438]: {"level":"info","ts":1663593413.1497974,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":""}
Sep 19 13:16:53 ip-172-31-41-174 caddy[438]: {"level":"info","ts":1663593413.1950748,"logger":"admin","msg":"admin endpoint started","address":"tcp/localhost:2019","enforce_origin":false,"origins":["//127.0.0.1:2019","//localhost:2019","//[::1]:2019"]}
Sep 19 13:16:53 ip-172-31-41-174 caddy[438]: {"level":"warn","ts":1663593413.1958282,"logger":"http","msg":"server is listening only on the HTTP port, so no automatic HTTPS will be applied to this server","server_name":"srv0","http_port":80}
Sep 19 13:16:53 ip-172-31-41-174 caddy[438]: {"level":"info","ts":1663593413.2093222,"logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0xc0001acd90"}
At first I thought this was an Angular issue, and tried some things that I don’t believe are relevant. Then I realized that the problem had to be with the url specifically being requested. So I tried changing the Caddyfile in a number of different ways as it seems you can do the same thing in multiple fashions. Only when I tried navigating to the url without the parameters did I realize that was the root of the issue, and I don’t see anything in the docs that looks to speak to this issue.
