- The reverse proxy handler is giving a connection refused response.
- Pinging receives a response which makes it seem like the connection to the other server is alright.
- The other server (being reverse proxied to) does not seem to receive any request so I think the request stops at the Caddy proxy server.
I do not have a lot of experience with network configuration and I’m wondering how I can debug this further? I expected that pinging would not work and that I could use that to test further but since it works… I’m feeling at a loss for how to check what’s happening?
I’m sure this is not an issue with Caddy but hoping someone has an idea of what I can look into next.
"level":"error","ts":1684834534.0603356,"logger":"http.log.error.platform","msg":"dial tcp [ipv6]:8088: connect: connection refused"
user@host:/# ping6 ipv6
PING ipv6(ipv6) 56 data bytes
64 bytes from ipv6: icmp_seq=1 ttl=62 time=0.357 ms
64 bytes from ipv6: icmp_seq=2 ttl=62 time=0.377 ms
64 bytes from ipv6: icmp_seq=3 ttl=62 time=0.377 ms
64 bytes from ipv6: icmp_seq=4 ttl=62 time=0.421 ms
Docker, Debian, run on Fly.io VM using Tailscale MagicDNS. Caddy issues the Tailscale HTTPS certificate just fine.
Starts container:
sysctl -w net.core.rmem_max=2048000
tailscaled --state=/var/lib/tailscale/tailscaled.state --socket=/var/run/tailscale/tailscaled.sock &
sleep 5
if [ ! -S /var/run/tailscale/tailscaled.sock ]; then
echo "tailscaled.sock does not exist. exit!"
exit 1
fi
until tailscale up --authkey=${TS_AUTHKEY} --hostname=${TS_HOSTNAME}
do
sleep 0.1
done
caddy run --config /config/caddy/caddy.json
If the Fly.io configuration is relevant I can post it.
"apps": {
"http": {
"https_port": 443,
"servers": {
"services": {
"listen": [":443"],
"trusted_proxies": {
"source": "static",
"ranges": [
"172.16.0.0/16",
"172.19.0.0/16"
"logs": {
"default_logger_name": "platform"
"routes": [
"handle": [
"handler": "subroute",
"routes": [
"match": [
"host": [
"fly-host.tailnet-name.ts.net"
"handle": [
"handler": "reverse_proxy",
"upstreams": [
"dial": "fly-host.internal:8088"
"terminal": true
