@Mohammed90 Thank you for your patience with me.
Indeed, making the following change to Caddyfile
reverse_proxy @cel_backend_node rp-tailscale.esco.ghaar:8443 {
#tls_insecure_skip_verify
tls_trust_pool file {
pem_file /opt/caddy/certificates/ldap_acme_actualroot_ca.crt
where ldap_acme_actualroot_ca.crt is my ACME’s root cert, along w/ changing the Node.js (upstream) code to
var certFile,
certKey = null
if (envNodeEnv === 'development') {
certFile = envHttpsCertFile || 'certs/devnode.crt'
certKey = envHttpsKeyFile || 'certs/devnode.key'
} else {
// assume its 'production' environment.
certFile = envHttpsCertFile || 'certs/prodnode.crt'
certKey = envHttpsKeyFile || 'certs/prodnode.key'
try {
var privateKey = fs.readFileSync(path.resolve(__dirname, certKey), 'utf8')
var certificate = fs.readFileSync(path.resolve(__dirname, certFile), 'utf8')
} catch (error) {
logger.error('Certificates can not be read')
logger.error(`Secure HTTP server can not be started.\n ${error}\n EXITING`)
gracefulShutdown()
where devnode.crt points to fullchain.pem (complete chain as issued by step-ca) of rp-tailscale.esco.ghaar (VM1 host node running Node.js + react) and devnode.key points to privkey.pem
works!
Jun 27 15:15:46 rp-tailscale caddy[339064]: {"level":"debug","ts":1719526546.4749594,"logger":"tls.handshake","msg":"choosing certificate","identifier":"liveliteandwell.com","num_choices":1}
Jun 27 15:15:46 rp-tailscale caddy[339064]: {"level":"debug","ts":1719526546.4749887,"logger":"tls.handshake","msg":"default certificate selection results","identifier":"liveliteandwell.com","subjects":["liveliteandwell.com"],"managed":true,"issuer_key":"acme-v02.api.letsencrypt.org-directory","hash":"8e02fc2b7fd7fdf007881e7004fe00a66666501929f409bdc8344a0ab77e6baf"}
Jun 27 15:15:46 rp-tailscale caddy[339064]: {"level":"debug","ts":1719526546.4750075,"logger":"tls.handshake","msg":"matched certificate in cache","remote_ip":"192.168.0.28","remote_port":"52741","subjects":["liveliteandwell.com"],"managed":true,"expiration":1726361429,"hash":"8e02fc2b7fd7fdf007881e7004fe00a66666501929f409bdc8344a0ab77e6baf"}
Jun 27 15:15:46 rp-tailscale caddy[339064]: {"level":"debug","ts":1719526546.5051308,"logger":"http.handlers.reverse_proxy","msg":"selected upstream","dial":"rp-tailscale.esco.ghaar:8443","total_upstreams":1}
Jun 27 15:15:46 rp-tailscale caddy[339064]: {"level":"debug","ts":1719526546.807779,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip","upstream":"rp-tailscale.esco.ghaar:8443","duration":0.30253505,"request":{"remote_ip":"192.168.0.28","remote_port":"52741","client_ip":"192.168.0.28","proto":"HTTP/2.0","method":"POST","host":"liveliteandwell.com","uri":"/api/login","headers":{"X-Forwarded-Host":["liveliteandwell.com"],"User-Agent":["curl/8.4.0"],"Accept":["*/*"],"Content-Type":["application/json"],"Content-Length":["53"],"X-Forwarded-For":["192.168.0.28"],"X-Forwarded-Proto":["https"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"liveliteandwell.com"}},"headers":{"Origin-Agent-Cluster":["?1"],"X-Frame-Options":["SAMEORIGIN"],"X-Download-Options":["noopen"],"Keep-Alive":["timeout=5"],"Cross-Origin-Resource-Policy":["same-origin"],"Referrer-Policy":["no-referrer"],"X-Dns-Prefetch-Control":["off"],"Date":["Thu, 27 Jun 2024 22:15:46 GMT"],"Connection":["keep-alive"],"Content-Security-Policy":["default-src 'self';base-uri 'self';font-src 'self' https: data:;form-action 'self';frame-ancestors 'self';img-src 'self' data:;object-src 'none';script-src 'self';script-src-attr 'none';style-src 'self' https: 'unsafe-inline';upgrade-insecure-requests"],"X-Content-Type-Options":["nosniff"],"X-Permitted-Cross-Domain-Policies":["none"],"Content-Length":["34"],"Cross-Origin-Opener-Policy":["same-origin"],"Strict-Transport-Security":["max-age=15552000; includeSubDomains"],"X-Xss-Protection":["0"]},"status":422}
Jun 27 15:15:46 rp-tailscale caddy[339064]: {"level":"info","ts":1719526546.8080058,"logger":"http.log.access","msg":"handled request","request":{"remote_ip":"192.168.0.28","remote_port":"52741","client_ip":"192.168.0.28","proto":"HTTP/2.0","method":"POST","host":"liveliteandwell.com","uri":"/api/login","headers":{"Content-Type":["application/json"],"Content-Length":["53"],"User-Agent":["curl/8.4.0"],"Accept":["*/*"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"liveliteandwell.com"}},"bytes_read":53,"user_id":"","duration":0.303025555,"size":34,"status":422,"resp_headers":{"Server":["Caddy"],"X-Frame-Options":["SAMEORIGIN"],"Referrer-Policy":["no-referrer"],"X-Content-Type-Options":["nosniff"],"Cross-Origin-Opener-Policy":["same-origin"],"Cross-Origin-Resource-Policy":["same-origin"],"X-Dns-Prefetch-Control":["off"],"Content-Security-Policy":["default-src 'self';base-uri 'self';font-src 'self' https: data:;form-action 'self';frame-ancestors 'self';img-src 'self' data:;object-src 'none';script-src 'self';script-src-attr 'none';style-src 'self' https: 'unsafe-inline';upgrade-insecure-requests"],"X-Permitted-Cross-Domain-Policies":["none"],"Content-Length":["34"],"Origin-Agent-Cluster":["?1"],"X-Download-Options":["noopen"],"Strict-Transport-Security":["max-age=15552000; includeSubDomains"],"X-Xss-Protection":["0"],"Alt-Svc":["h3=\":443\"; ma=2592000"],"Date":["Thu, 27 Jun 2024 22:15:46 GMT"]}}
Jun 27 15:16:19 rp-tailscale caddy[339064]: {"level":"debug","ts":1719526579.6771302,"logger":"events","msg":"event","name":"tls_get_certificate","id":"c680a2c2-ccd3-477a-97f0-8c62cee6d94f","origin":"tls","data":{"client_hello":{"CipherSuites":[4866,4867,4865,49200,49196,49192,49188,49172,49162,159,107,57,52393,52392,52394,65413,196,136,129,157,61,53,192,132,49199,49195,49191,49187,49171,49161,158,103,51,190,69,156,60,47,186,65,49169,49159,5,4,49170,49160,22,10,255],"ServerName":"liveliteandwell.com","SupportedCurves":[29,23,24,25],"SupportedPoints":"AA==","SignatureSchemes":[2054,1537,1539,2053,1281,1283,2052,1025,1027,513,515],"SupportedProtos":["h2","http/1.1"],"SupportedVersions":[772,771,770,769],"RemoteAddr":{"IP":"192.168.0.28","Port":52750,"Zone":""},"LocalAddr":{"IP":"192.168.100.17","Port":443,"Zone":""}}}}
Jun 27 15:16:19 rp-tailscale caddy[339064]: {"level":"debug","ts":1719526579.677233,"logger":"tls.handshake","msg":"choosing certificate","identifier":"liveliteandwell.com","num_choices":1}
The reason I went down the rabbit hole of specifying ca, ca_root (or acme_server) under tls under a separate call out for rp-tailscale.ecso.ghaar in Caddyfile is the desire to obtain caddy metrics. To do so, I need an entry like
metrics /metrics
But doing so will tell Caddy to contact LE’s ACME to obtain certs.
