Running a simple proxy through the Windows 11 or git bash, using it for jellyfish streaming. Bandwidth is fine once the proxy is first ran on a fresh config but after several minutes it slows down to maybe max 4mbps. I have no config just the simple reverse proxy command in my caddy file as shown below. Everything connects fine it just tanks the network usage for some reason when streaming video. To get it working properly again for a bit before it tanks I run caddy stop then caddy reload several times.
My only other set up is ports 443 and 80 forwarded and cloud flare DNS without cloud flare proxy, just dns. My hostname loads fine just usage tanks when streaming.
Should I be doing this in docker? Does this have to do with websocket buffering ? Is it a WSL bandwidth thing? Anyone have any suggestions for what it could be or if I’m missing something?
Jellyfin.example.com
reverse proxy localhost:8096
