danilolr
(DANILO RHEINHEIMER)
March 29, 2018, 12:36pm
#1
I am using caddy as the reverse proxy to a application server. This is fine.
But to some path on request I need the files server from disk.
So if some one access :
https://www.mydomain.com/x/y/z
It must be redirected to the reverse proxy.
But if someone access :
https://www.mydomain.com/audio/myaudio.wav
The file myaudio.wav must be served from the file /opt/audio
Of couse the dir /opt/audio contains myaudio.wav
So if the accessed url starts with /audio the content is server from the directory otherwise it goes to the reverse proxy.
I try to use rewrite directive but I am missing something.
Hi @danilolr ,
You can use the except
subdirective to declare a base path not to proxy from, like except /audio
except is a space-separated list of paths to exclude from proxying. Requests that match any of ignored_paths will be passed thru.
– https://caddyserver.com/docs/proxy
danilolr
March 31, 2018, 10:48am
#3
Hi @Whitestrake this solved my use case right now. Thanks.
I did create an except to audio and set root to the parent directory of the audio dir.
So it is working fine.
system
(system)
closed
June 29, 2018, 10:48am
#4
