2.4.3
Using docker-compose
Ubuntu 20.04 with docker
I use this dockerfile
FROM caddy:2.4.3-builder-alpine AS builder
RUN xcaddy build \
--with github.com/mholt/caddy-ratelimit
FROM caddy:2.4.3-alpine
slimurl_caddy_server:
depends_on:
- slimurl_api
- slimurl_portainer
container_name: slimurl_caddy_server
image: slimurl-caddy-server
- 443:443
- CADDY_INGRESS_NETWORKS=caddy
- slimurl_caddy_data:/data
- slimurl_caddy_config:/config
- $PWD/caddy-server/.Caddyfile:/etc/caddy/Caddyfile
- $PWD/caddy-server/logs:/var/log/caddy
- slimurl
order rate_limit before basicauth
admin off
#To use snippet inside directive "import rate_limit_per_min {zoneName} {numRequests} {minutes}"
(rate_limit_per_min) {
rate_limit {
zone {args.0} {
key {http.request.remote.host}
events {args.1}
window {args.2}m
#Import same as above snippet, first argument is file where to save logs inside the "/var/log/caddy" folder
(log_to_file) {
format filter {
wrap json
fields {
request>headers>Authorization delete
output file /var/log/caddy/{args.0} {
roll_size 500mb
roll_keep 10
roll_keep_for 2880h
#Redirect www.api.slimurl.me/* to uri without it
www.api.slimurl.me {
redir https://api.slimurl.me{uri}
#Handle the actual uri here
api.slimurl.me {
encode zstd gzip
reverse_proxy /* http://slimurl_api:80
import log_to_file apiLog.log
route /user/register {
import rate_limit_per_min register_zone 3 60
route /user/login {
import rate_limit_per_min login_zone 5 20
#Frontend
www.slimurl.me {
redir https://slimurl.me{uri}
slimurl.me {
reverse_proxy http://slimurl_frontend:80
I want to make it so that the frontend directive, slimurl.me reverse proxies to the http://slimurl_frontend:80 only for specific routes and every other route to be forwarded to a backend route api.slimurl.me/redirect/{uri} but no matter what I try I cannot get it to work. If I try to use multiple directives my frontend either stops working or all my requests are forwarded to the backend. I would very much appreciate the help.
I tried making a matcher and redirecting everything else not matched to the backend but it’s not working
slimurl.me {
@paths {
path /login*
path /profile*
path /
reverse_proxy @paths http://slimurl_frontend:80
redir not @paths http://api.slimurl.me/redirect{uri}
### 6. Links to relevant resources:
