Oh bother, oh well easy fix. Just adding 1.1.1.1 as a forwarder in my Bind9 config didn’t seem to really change anything, but adding the revolvers seems to have made a difference.
Caddyfile:
(prop) {
tls my@email.net {
resolvers 1.1.1.1
dns cloudflare api-token
smx.ecfinternal.net {
reverse_proxy https://10.0.0.7:3443
import prop
curl -v https://smx.ecfinternal.net
* Connected to smx.ecfinternal.net (10.0.0.13) port 443 (#0)
* ALPN, offering h2
* ALPN, offering http/1.1
* CApath: /etc/ssl/certs
* TLSv1.2 (IN), TLS header, Certificate Status (22):
* TLSv1.2 (IN), TLS header, Finished (20):
* TLSv1.2 (IN), TLS header, Supplemental data (23):
* TLSv1.2 (OUT), TLS header, Finished (20):
* TLSv1.2 (OUT), TLS header, Supplemental data (23):
* subject: CN=smx.ecfinternal.net
* start date: May 10 15:20:05 2024 GMT
* expire date: Aug 8 15:20:04 2024 GMT
* subjectAltName: host "smx.ecfinternal.net" matched cert's "smx.ecfinternal.net"
* issuer: C=US; O=Let's Encrypt; CN=R3
* SSL certificate verify ok.
* Using Stream ID: 1 (easy handle 0x55e462767eb0)
> GET / HTTP/2
> Host: smx.ecfinternal.net
> user-agent: curl/7.81.0
> accept: */*
< HTTP/2 502
< server: Caddy
< content-length: 0
< date: Fri, 10 May 2024 16:22:45 GMT
* Connection #0 to host smx.ecfinternal.net left intact
Logs:
May 10 12:19:49 auth systemd[1]: Started Caddy.
May 10 12:19:49 auth caddy[60234]: {"level":"info","ts":1715357989.4549055,"msg":"serving initial configuration"}
May 10 12:19:49 auth caddy[60234]: {"level":"info","ts":1715357989.4551482,"logger":"tls.obtain","msg":"acquiring lock","identifier":"smx.ecfinternal.net"}
May 10 12:19:49 auth caddy[60234]: {"level":"info","ts":1715357989.458124,"logger":"tls","msg":"cleaning storage unit","storage":"FileStorage:/var/lib/caddy/.local/share/caddy"}
May 10 12:19:49 auth caddy[60234]: {"level":"info","ts":1715357989.4591122,"logger":"tls","msg":"finished cleaning storage units"}
May 10 12:19:49 auth caddy[60234]: {"level":"info","ts":1715357989.4600208,"logger":"tls.obtain","msg":"lock acquired","identifier":"smx.ecfinternal.net"}
May 10 12:19:49 auth caddy[60234]: {"level":"info","ts":1715357989.4601762,"logger":"tls.obtain","msg":"obtaining certificate","identifier":"smx.ecfinternal.net"}
May 10 12:19:49 auth caddy[60234]: {"level":"debug","ts":1715357989.460329,"logger":"events","msg":"event","name":"cert_obtaining","id":"722decab-b27d-4f04-8d64-9741323199d1","origin":"tls","data":{"identifier":"smx.ecfinternal.net"}}
May 10 12:19:49 auth caddy[60234]: {"level":"debug","ts":1715357989.460586,"logger":"tls.obtain","msg":"trying issuer 1/2","issuer":"acme-v02.api.letsencrypt.org-directory"}
May 10 12:19:49 auth caddy[60234]: {"level":"debug","ts":1715357989.6445978,"logger":"tls.issuance.acme.acme_client","msg":"http request","method":"GET","url":"https://acme-v02.api.letsencrypt.org/directory","headers":{"User-Agent":["Caddy/2.8.0-beta.2 CertMagic acmez (linux; amd64)"]},"response_headers":{"Cache-Control":["public, max-age=0, no-cache"],"Content-Length":["747"],"Content-Type":["application/json"],"Date":["Fri, 10 May 2024 16:19:49 GMT"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]},"status_code":200}
May 10 12:19:49 auth caddy[60234]: {"level":"debug","ts":1715357989.7024877,"logger":"tls.issuance.acme.acme_client","msg":"http request","method":"HEAD","url":"https://acme-v02.api.letsencrypt.org/acme/new-nonce","headers":{"User-Agent":["Caddy/2.8.0-beta.2 CertMagic acmez (linux; amd64)"]},"response_headers":{"Cache-Control":["public, max-age=0, no-cache"],"Date":["Fri, 10 May 2024 16:19:49 GMT"],"Link":["<https://acme-v02.api.letsencrypt.org/directory>;rel=\"index\""],"Replay-Nonce":["6Jd4kJYipivjaBesyRi3M-x-0Jc1rvptbzWXj0Ce4j0i8bH-efo"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]},"status_code":200}
May 10 12:19:49 auth caddy[60234]: {"level":"debug","ts":1715357989.7714572,"logger":"tls.issuance.acme.acme_client","msg":"http request","method":"POST","url":"https://acme-v02.api.letsencrypt.org/acme/new-acct","headers":{"Content-Type":["application/jose+json"],"User-Agent":["Caddy/2.8.0-beta.2 CertMagic acmez (linux; amd64)"]},"response_headers":{"Boulder-Requester":["1719474267"],"Cache-Control":["public, max-age=0, no-cache"],"Content-Length":["326"],"Content-Type":["application/json"],"Date":["Fri, 10 May 2024 16:19:49 GMT"],"Link":["<https://acme-v02.api.letsencrypt.org/directory>;rel=\"index\"","<https://letsencrypt.org/documents/LE-SA-v1.4-April-3-2024.pdf>;rel=\"terms-of-service\""],"Location":["https://acme-v02.api.letsencrypt.org/acme/acct/1719474267"],"Replay-Nonce":["7n34iCGf_cSyFZiAjJdpJ2NST3hUR2nG4xq9vpocUJPMTZ37wRY"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]},"status_code":201}
May 10 12:19:49 auth caddy[60234]: {"level":"info","ts":1715357989.771839,"logger":"tls.issuance.acme","msg":"waiting on internal rate limiter","identifiers":["smx.ecfinternal.net"],"ca":"https://acme-v02.api.letsencrypt.org/directory","account":"my@email.net"}
May 10 12:19:49 auth caddy[60234]: {"level":"info","ts":1715357989.771852,"logger":"tls.issuance.acme","msg":"done waiting on internal rate limiter","identifiers":["smx.ecfinternal.net"],"ca":"https://acme-v02.api.letsencrypt.org/directory","account":"my@email.net"}
May 10 12:19:49 auth caddy[60234]: {"level":"info","ts":1715357989.7718716,"logger":"tls.issuance.acme","msg":"using ACME account","account_id":"https://acme-v02.api.letsencrypt.org/acme/acct/1719474267","account_contact":["mailto:my@email.net"]}
May 10 12:19:49 auth caddy[60234]: {"level":"debug","ts":1715357989.7718768,"logger":"tls.issuance.acme.acme_client","msg":"creating order","account":"https://acme-v02.api.letsencrypt.org/acme/acct/1719474267","identifiers":["smx.ecfinternal.net"]}
May 10 12:19:49 auth caddy[60234]: {"level":"debug","ts":1715357989.8565054,"logger":"tls.issuance.acme.acme_client","msg":"http request","method":"POST","url":"https://acme-v02.api.letsencrypt.org/acme/new-order","headers":{"Content-Type":["application/jose+json"],"User-Agent":["Caddy/2.8.0-beta.2 CertMagic acmez (linux; amd64)"]},"response_headers":{"Boulder-Requester":["1719474267"],"Cache-Control":["public, max-age=0, no-cache"],"Content-Length":["345"],"Content-Type":["application/json"],"Date":["Fri, 10 May 2024 16:19:49 GMT"],"Link":["<https://acme-v02.api.letsencrypt.org/directory>;rel=\"index\""],"Location":["https://acme-v02.api.letsencrypt.org/acme/order/1719474267/268242330127"],"Replay-Nonce":["6Jd4kJYiTT1kErfPw6ZV4J6-kCi5KSIBbFJ6LnM7OIMhgAjNMj4"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]},"status_code":201}
May 10 12:19:49 auth caddy[60234]: {"level":"debug","ts":1715357989.9188807,"logger":"tls.issuance.acme.acme_client","msg":"http request","method":"POST","url":"https://acme-v02.api.letsencrypt.org/acme/authz-v3/349078965197","headers":{"Content-Type":["application/jose+json"],"User-Agent":["Caddy/2.8.0-beta.2 CertMagic acmez (linux; amd64)"]},"response_headers":{"Boulder-Requester":["1719474267"],"Cache-Control":["public, max-age=0, no-cache"],"Content-Length":["803"],"Content-Type":["application/json"],"Date":["Fri, 10 May 2024 16:19:49 GMT"],"Link":["<https://acme-v02.api.letsencrypt.org/directory>;rel=\"index\""],"Replay-Nonce":["6Jd4kJYiZdKIDoJJdy4uhmFGStSotyyznZXfwLi3zSUC6FYz6ps"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]},"status_code":200}
May 10 12:19:49 auth caddy[60234]: {"level":"info","ts":1715357989.9189768,"logger":"tls.issuance.acme.acme_client","msg":"trying to solve challenge","identifier":"smx.ecfinternal.net","challenge_type":"dns-01","ca":"https://acme-v02.api.letsencrypt.org/directory"}
May 10 12:19:50 auth caddy[60234]: {"level":"debug","ts":1715357990.7676342,"logger":"tls.issuance.acme.acme_client","msg":"waiting for solver before continuing","identifier":"smx.ecfinternal.net","challenge_type":"dns-01"}
May 10 12:20:03 auth caddy[60234]: {"level":"debug","ts":1715358003.173214,"logger":"tls.issuance.acme.acme_client","msg":"done waiting for solver","identifier":"smx.ecfinternal.net","challenge_type":"dns-01"}
May 10 12:20:03 auth caddy[60234]: {"level":"debug","ts":1715358003.2361262,"logger":"tls.issuance.acme.acme_client","msg":"http request","method":"POST","url":"https://acme-v02.api.letsencrypt.org/acme/chall-v3/349078965197/Lu-8XQ","headers":{"Content-Type":["application/jose+json"],"User-Agent":["Caddy/2.8.0-beta.2 CertMagic acmez (linux; amd64)"]},"response_headers":{"Boulder-Requester":["1719474267"],"Cache-Control":["public, max-age=0, no-cache"],"Content-Length":["186"],"Content-Type":["application/json"],"Date":["Fri, 10 May 2024 16:20:03 GMT"],"Link":["<https://acme-v02.api.letsencrypt.org/directory>;rel=\"index\"","<https://acme-v02.api.letsencrypt.org/acme/authz-v3/349078965197>;rel=\"up\""],"Location":["https://acme-v02.api.letsencrypt.org/acme/chall-v3/349078965197/Lu-8XQ"],"Replay-Nonce":["6Jd4kJYidxwBYHXTb3rUFVaaJ3-8X60eZlY6VvjY59kFazQZePk"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]},"status_code":200}
May 10 12:20:03 auth caddy[60234]: {"level":"debug","ts":1715358003.2361805,"logger":"tls.issuance.acme.acme_client","msg":"challenge accepted","identifier":"smx.ecfinternal.net","challenge_type":"dns-01"}
May 10 12:20:03 auth caddy[60234]: {"level":"debug","ts":1715358003.5473006,"logger":"tls.issuance.acme.acme_client","msg":"http request","method":"POST","url":"https://acme-v02.api.letsencrypt.org/acme/authz-v3/349078965197","headers":{"Content-Type":["application/jose+json"],"User-Agent":["Caddy/2.8.0-beta.2 CertMagic acmez (linux; amd64)"]},"response_headers":{"Boulder-Requester":["1719474267"],"Cache-Control":["public, max-age=0, no-cache"],"Content-Length":["513"],"Content-Type":["application/json"],"Date":["Fri, 10 May 2024 16:20:03 GMT"],"Link":["<https://acme-v02.api.letsencrypt.org/directory>;rel=\"index\""],"Replay-Nonce":["6Jd4kJYi1spCGMG8ySuWbBGiS56NoESM36jXInNGJJxVpuHaZBA"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]},"status_code":200}
May 10 12:20:04 auth caddy[60234]: {"level":"info","ts":1715358004.9590812,"logger":"tls.issuance.acme.acme_client","msg":"authorization finalized","identifier":"smx.ecfinternal.net","authz_status":"valid"}
May 10 12:20:04 auth caddy[60234]: {"level":"info","ts":1715358004.9591327,"logger":"tls.issuance.acme.acme_client","msg":"validations succeeded; finalizing order","order":"https://acme-v02.api.letsencrypt.org/acme/order/1719474267/268242330127"}
May 10 12:20:05 auth caddy[60234]: {"level":"debug","ts":1715358005.7923877,"logger":"tls.issuance.acme.acme_client","msg":"http request","method":"POST","url":"https://acme-v02.api.letsencrypt.org/acme/finalize/1719474267/268242330127","headers":{"Content-Type":["application/jose+json"],"User-Agent":["Caddy/2.8.0-beta.2 CertMagic acmez (linux; amd64)"]},"response_headers":{"Boulder-Requester":["1719474267"],"Cache-Control":["public, max-age=0, no-cache"],"Content-Length":["447"],"Content-Type":["application/json"],"Date":["Fri, 10 May 2024 16:20:05 GMT"],"Link":["<https://acme-v02.api.letsencrypt.org/directory>;rel=\"index\""],"Location":["https://acme-v02.api.letsencrypt.org/acme/order/1719474267/268242330127"],"Replay-Nonce":["7n34iCGfqEj5LF7hLp_Y-rf8xpO_ohZI6srH5IPC8T6NpyNojRA"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]},"status_code":200}
May 10 12:20:05 auth caddy[60234]: {"level":"debug","ts":1715358005.8546913,"logger":"tls.issuance.acme.acme_client","msg":"http request","method":"POST","url":"https://acme-v02.api.letsencrypt.org/acme/cert/03aa1485a8799b8c2c837f70572004047cda","headers":{"Content-Type":["application/jose+json"],"User-Agent":["Caddy/2.8.0-beta.2 CertMagic acmez (linux; amd64)"]},"response_headers":{"Cache-Control":["public, max-age=0, no-cache"],"Content-Length":["3332"],"Content-Type":["application/pem-certificate-chain"],"Date":["Fri, 10 May 2024 16:20:05 GMT"],"Link":["<https://acme-v02.api.letsencrypt.org/directory>;rel=\"index\"","<https://acme-v02.api.letsencrypt.org/acme/cert/03aa1485a8799b8c2c837f70572004047cda/1>;rel=\"alternate\""],"Replay-Nonce":["7n34iCGf_1Z0HsKilreIQ-50NKJtF7MtqYvln_QPBUb33-K8u00"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]},"status_code":200}
May 10 12:20:05 auth caddy[60234]: {"level":"debug","ts":1715358005.8547878,"logger":"tls.issuance.acme.acme_client","msg":"getting renewal info","names":["smx.ecfinternal.net"]}
May 10 12:20:05 auth caddy[60234]: {"level":"debug","ts":1715358005.9769819,"logger":"tls.issuance.acme.acme_client","msg":"http request","method":"GET","url":"https://acme-v02.api.letsencrypt.org/draft-ietf-acme-ari-02/renewalInfo//FC6zF7dYVsuuUAlA5h-vnYsUwsY.A6oUhah5m4wsg39wVyAEBHza","headers":{"User-Agent":["Caddy/2.8.0-beta.2 CertMagic acmez (linux; amd64)"]},"response_headers":{"Cache-Control":["public, max-age=0, no-cache"],"Content-Length":["101"],"Content-Type":["application/json"],"Date":["Fri, 10 May 2024 16:20:05 GMT"],"Link":["<https://acme-v02.api.letsencrypt.org/directory>;rel=\"index\""],"Retry-After":["21600"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]},"status_code":200}
May 10 12:20:05 auth caddy[60234]: {"level":"info","ts":1715358005.9770653,"logger":"tls.issuance.acme.acme_client","msg":"got renewal info","names":["smx.ecfinternal.net"],"window_start":1720453204,"window_end":1720626004,"selected_time":1720484247,"recheck_after":1715379605.9770608,"explanation_url":""}
May 10 12:20:06 auth caddy[60234]: {"level":"debug","ts":1715358006.0387075,"logger":"tls.issuance.acme.acme_client","msg":"http request","method":"POST","url":"https://acme-v02.api.letsencrypt.org/acme/cert/03aa1485a8799b8c2c837f70572004047cda/1","headers":{"Content-Type":["application/jose+json"],"User-Agent":["Caddy/2.8.0-beta.2 CertMagic acmez (linux; amd64)"]},"response_headers":{"Cache-Control":["public, max-age=0, no-cache"],"Content-Length":["5256"],"Content-Type":["application/pem-certificate-chain"],"Date":["Fri, 10 May 2024 16:20:06 GMT"],"Link":["<https://acme-v02.api.letsencrypt.org/directory>;rel=\"index\"","<https://acme-v02.api.letsencrypt.org/acme/cert/03aa1485a8799b8c2c837f70572004047cda/0>;rel=\"alternate\""],"Replay-Nonce":["7n34iCGf9sDyA1xPNI0L_G-LFGwYcv_B4uHEHIN8H1To3BJihFU"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]},"status_code":200}
May 10 12:20:06 auth caddy[60234]: {"level":"debug","ts":1715358006.038788,"logger":"tls.issuance.acme.acme_client","msg":"getting renewal info","names":["smx.ecfinternal.net"]}
May 10 12:20:06 auth caddy[60234]: {"level":"debug","ts":1715358006.1607723,"logger":"tls.issuance.acme.acme_client","msg":"http request","method":"GET","url":"https://acme-v02.api.letsencrypt.org/draft-ietf-acme-ari-02/renewalInfo//FC6zF7dYVsuuUAlA5h-vnYsUwsY.A6oUhah5m4wsg39wVyAEBHza","headers":{"User-Agent":["Caddy/2.8.0-beta.2 CertMagic acmez (linux; amd64)"]},"response_headers":{"Cache-Control":["public, max-age=0, no-cache"],"Content-Length":["101"],"Content-Type":["application/json"],"Date":["Fri, 10 May 2024 16:20:06 GMT"],"Link":["<https://acme-v02.api.letsencrypt.org/directory>;rel=\"index\""],"Retry-After":["21600"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]},"status_code":200}
May 10 12:20:06 auth caddy[60234]: {"level":"info","ts":1715358006.1608286,"logger":"tls.issuance.acme.acme_client","msg":"got renewal info","names":["smx.ecfinternal.net"],"window_start":1720453204,"window_end":1720626004,"selected_time":1720504140,"recheck_after":1715379606.1608255,"explanation_url":""}
May 10 12:20:06 auth caddy[60234]: {"level":"info","ts":1715358006.1608448,"logger":"tls.issuance.acme.acme_client","msg":"successfully downloaded available certificate chains","count":2,"first_url":"https://acme-v02.api.letsencrypt.org/acme/cert/03aa1485a8799b8c2c837f70572004047cda"}
May 10 12:20:06 auth caddy[60234]: {"level":"debug","ts":1715358006.1608493,"logger":"tls.issuance.acme","msg":"selected certificate chain","url":"https://acme-v02.api.letsencrypt.org/acme/cert/03aa1485a8799b8c2c837f70572004047cda"}
May 10 12:20:06 auth caddy[60234]: {"level":"info","ts":1715358006.1611915,"logger":"tls.obtain","msg":"certificate obtained successfully","identifier":"smx.ecfinternal.net","issuer":"acme-v02.api.letsencrypt.org-directory"}
May 10 12:20:06 auth caddy[60234]: {"level":"debug","ts":1715358006.1612663,"logger":"events","msg":"event","name":"cert_obtained","id":"97587806-757d-47df-acd4-44da1b81913f","origin":"tls","data":{"certificate_path":"certificates/acme-v02.api.letsencrypt.org-directory/smx.ecfinternal.net/smx.ecfinternal.net.crt","csr_pem":"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","identifier":"smx.ecfinternal.net","issuer":"acme-v02.api.letsencrypt.org-directory","metadata_path":"certificates/acme-v02.api.letsencrypt.org-directory/smx.ecfinternal.net/smx.ecfinternal.net.json","private_key_path":"certificates/acme-v02.api.letsencrypt.org-directory/smx.ecfinternal.net/smx.ecfinternal.net.key","renewal":false,"storage_path":"certificates/acme-v02.api.letsencrypt.org-directory/smx.ecfinternal.net"}}
May 10 12:20:06 auth caddy[60234]: {"level":"info","ts":1715358006.1613748,"logger":"tls.obtain","msg":"releasing lock","identifier":"smx.ecfinternal.net"}
May 10 12:20:06 auth caddy[60234]: {"level":"debug","ts":1715358006.1616058,"logger":"tls","msg":"loading managed certificate","domain":"smx.ecfinternal.net","expiration":1723130405,"issuer_key":"acme-v02.api.letsencrypt.org-directory","storage":"FileStorage:/var/lib/caddy/.local/share/caddy"}
May 10 12:20:06 auth caddy[60234]: {"level":"debug","ts":1715358006.326834,"logger":"tls.cache","msg":"added certificate to cache","subjects":["smx.ecfinternal.net"],"expiration":1723130405,"managed":true,"issuer_key":"acme-v02.api.letsencrypt.org-directory","hash":"4213fb41b0ff4968c1fa5ceeca03f28086fa3436aefc34b83437f3f247337a1e","cache_size":1,"cache_capacity":10000}
May 10 12:20:06 auth caddy[60234]: {"level":"debug","ts":1715358006.3268735,"logger":"events","msg":"event","name":"cached_managed_cert","id":"735a8e23-627f-428b-9904-64bb2778601b","origin":"tls","data":{"sans":["smx.ecfinternal.net"]}}
May 10 12:22:45 auth caddy[60234]: {"level":"debug","ts":1715358165.3133073,"logger":"events","msg":"event","name":"tls_get_certificate","id":"7b9dab9b-92df-4b67-a2fc-2782b807bc09","origin":"tls","data":{"client_hello":{"CipherSuites":[4866,4867,4865,49196,49200,159,52393,52392,52394,49195,49199,158,49188,49192,107,49187,49191,103,49162,49172,57,49161,49171,51,157,156,61,60,53,47,255],"ServerName":"smx.ecfinternal.net","SupportedCurves":[29,23,30,25,24,256,257,258,259,260],"SupportedPoints":"AAEC","SignatureSchemes":[1027,1283,1539,2055,2056,2057,2058,2059,2052,2053,2054,1025,1281,1537,771,769,770,1026,1282,1538],"SupportedProtos":["h2","http/1.1"],"SupportedVersions":[772,771],"RemoteAddr":{"IP":"10.0.0.13","Port":39490,"Zone":""},"LocalAddr":{"IP":"10.0.0.13","Port":443,"Zone":""}}}}
May 10 12:22:45 auth caddy[60234]: {"level":"debug","ts":1715358165.3133512,"logger":"tls.handshake","msg":"choosing certificate","identifier":"smx.ecfinternal.net","num_choices":1}
May 10 12:22:45 auth caddy[60234]: {"level":"debug","ts":1715358165.3133786,"logger":"tls.handshake","msg":"default certificate selection results","identifier":"smx.ecfinternal.net","subjects":["smx.ecfinternal.net"],"managed":true,"issuer_key":"acme-v02.api.letsencrypt.org-directory","hash":"4213fb41b0ff4968c1fa5ceeca03f28086fa3436aefc34b83437f3f247337a1e"}
May 10 12:22:45 auth caddy[60234]: {"level":"debug","ts":1715358165.313389,"logger":"tls.handshake","msg":"matched certificate in cache","remote_ip":"10.0.0.13","remote_port":"39490","subjects":["smx.ecfinternal.net"],"managed":true,"expiration":1723130405,"hash":"4213fb41b0ff4968c1fa5ceeca03f28086fa3436aefc34b83437f3f247337a1e"}
May 10 12:22:45 auth caddy[60234]: {"level":"debug","ts":1715358165.3158677,"logger":"http.handlers.reverse_proxy","msg":"selected upstream","dial":"10.0.0.7:3443","total_upstreams":1}
May 10 12:22:45 auth caddy[60234]: {"level":"debug","ts":1715358165.3172507,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip","upstream":"10.0.0.7:3443","duration":0.001341967,"request":{"remote_ip":"10.0.0.13","remote_port":"39490","client_ip":"10.0.0.13","proto":"HTTP/2.0","method":"GET","host":"smx.ecfinternal.net","uri":"/","headers":{"User-Agent":["curl/7.81.0"],"Accept":["*/*"],"X-Forwarded-For":["10.0.0.13"],"X-Forwarded-Proto":["https"],"X-Forwarded-Host":["smx.ecfinternal.net"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"smx.ecfinternal.net"}},"error":"tls: failed to verify certificate: x509: cannot validate certificate for 10.0.0.7 because it doesn't contain any IP SANs"}
May 10 12:22:45 auth caddy[60234]: {"level":"error","ts":1715358165.3173223,"logger":"http.log.error","msg":"tls: failed to verify certificate: x509: cannot validate certificate for 10.0.0.7 because it doesn't contain any IP SANs","request":{"remote_ip":"10.0.0.13","remote_port":"39490","client_ip":"10.0.0.13","proto":"HTTP/2.0","method":"GET","host":"smx.ecfinternal.net","uri":"/","headers":{"Accept":["*/*"],"User-Agent":["curl/7.81.0"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"smx.ecfinternal.net"}},"duration":0.001513142,"status":502,"err_id":"b9yj9ihnz","err_trace":"reverseproxy.statusError (reverseproxy.go:1269)"}
May 10 12:24:41 auth caddy[60234]: {"level":"debug","ts":1715358281.6908927,"logger":"events","msg":"event","name":"tls_get_certificate","id":"8df90b23-1d12-47be-b11d-17c858d90774","origin":"tls","data":{"client_hello":{"CipherSuites":[10794,4865,4866,4867,49195,49199,49196,49200,52393,52392,49171,49172,156,157,47,53],"ServerName":"smx.ecfinternal.net","SupportedCurves":[10794,25497,29,23,24],"SupportedPoints":"AA==","SignatureSchemes":[1027,2052,1025,1283,2053,1281,2054,1537],"SupportedProtos":["h2","http/1.1"],"SupportedVersions":[39578,772,771],"RemoteAddr":{"IP":"10.212.134.205","Port":50578,"Zone":""},"LocalAddr":{"IP":"10.0.0.13","Port":443,"Zone":""}}}}
May 10 12:24:41 auth caddy[60234]: {"level":"debug","ts":1715358281.6909337,"logger":"tls.handshake","msg":"choosing certificate","identifier":"smx.ecfinternal.net","num_choices":1}
May 10 12:24:41 auth caddy[60234]: {"level":"debug","ts":1715358281.690981,"logger":"tls.handshake","msg":"default certificate selection results","identifier":"smx.ecfinternal.net","subjects":["smx.ecfinternal.net"],"managed":true,"issuer_key":"acme-v02.api.letsencrypt.org-directory","hash":"4213fb41b0ff4968c1fa5ceeca03f28086fa3436aefc34b83437f3f247337a1e"}
May 10 12:24:41 auth caddy[60234]: {"level":"debug","ts":1715358281.6909864,"logger":"tls.handshake","msg":"matched certificate in cache","remote_ip":"10.212.134.205","remote_port":"50578","subjects":["smx.ecfinternal.net"],"managed":true,"expiration":1723130405,"hash":"4213fb41b0ff4968c1fa5ceeca03f28086fa3436aefc34b83437f3f247337a1e"}
May 10 12:24:41 auth caddy[60234]: {"level":"debug","ts":1715358281.6965096,"logger":"http.handlers.reverse_proxy","msg":"selected upstream","dial":"10.0.0.7:3443","total_upstreams":1}
May 10 12:24:41 auth caddy[60234]: {"level":"debug","ts":1715358281.6976063,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip","upstream":"10.0.0.7:3443","duration":0.001054794,"request":{"remote_ip":"10.212.134.205","remote_port":"50578","client_ip":"10.212.134.205","proto":"HTTP/2.0","method":"GET","host":"smx.ecfinternal.net","uri":"/","headers":{"Sec-Ch-Ua":["\"Chromium\";v=\"124\", \"Google Chrome\";v=\"124\", \"Not-A.Brand\";v=\"99\""],"X-Forwarded-For":["10.212.134.205"],"Accept-Encoding":["gzip, deflate, br"],"Priority":["u=0, i"],"Sec-Fetch-User":["?1"],"User-Agent":["Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/124.0.0.0 Safari/537.36"],"Accept":["text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,image/apng,*/*;q=0.8,application/signed-exchange;v=b3;q=0.7"],"Sec-Fetch-Mode":["navigate"],"Sec-Fetch-Site":["none"],"Sec-Ch-Ua-Mobile":["?0"],"X-Forwarded-Proto":["https"],"Sec-Fetch-Dest":["document"],"Accept-Language":["en-US,en;q=0.9"],"X-Forwarded-Host":["smx.ecfinternal.net"],"Sec-Ch-Ua-Platform":["\"Linux\""],"Upgrade-Insecure-Requests":["1"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"smx.ecfinternal.net"}},"error":"tls: failed to verify certificate: x509: cannot validate certificate for 10.0.0.7 because it doesn't contain any IP SANs"}
May 10 12:24:41 auth caddy[60234]: {"level":"error","ts":1715358281.6976728,"logger":"http.log.error","msg":"tls: failed to verify certificate: x509: cannot validate certificate for 10.0.0.7 because it doesn't contain any IP SANs","request":{"remote_ip":"10.212.134.205","remote_port":"50578","client_ip":"10.212.134.205","proto":"HTTP/2.0","method":"GET","host":"smx.ecfinternal.net","uri":"/","headers":{"Accept-Encoding":["gzip, deflate, br"],"Accept-Language":["en-US,en;q=0.9"],"Priority":["u=0, i"],"Sec-Ch-Ua-Platform":["\"Linux\""],"Sec-Fetch-Site":["none"],"Sec-Fetch-User":["?1"],"Sec-Fetch-Dest":["document"],"Accept":["text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,image/apng,*/*;q=0.8,application/signed-exchange;v=b3;q=0.7"],"Sec-Fetch-Mode":["navigate"],"Sec-Ch-Ua":["\"Chromium\";v=\"124\", \"Google Chrome\";v=\"124\", \"Not-A.Brand\";v=\"99\""],"Sec-Ch-Ua-Mobile":["?0"],"Upgrade-Insecure-Requests":["1"],"User-Agent":["Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/124.0.0.0 Safari/537.36"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"smx.ecfinternal.net"}},"duration":0.00119966,"status":502,"err_id":"phxcj4jw4","err_trace":"reverseproxy.statusError (reverseproxy.go:1269)"}
May 10 12:24:48 auth caddy[60234]: {"level":"debug","ts":1715358288.5667534,"logger":"events","msg":"event","name":"tls_get_certificate","id":"f891ddb7-82f7-4a59-b3c1-e834f9a4ffbf","origin":"tls","data":{"client_hello":{"CipherSuites":[19018,4865,4866,4867,49195,49199,49196,49200,52393,52392,49171,49172,156,157,47,53],"ServerName":"smx","SupportedCurves":[64250,25497,29,23,24],"SupportedPoints":"AA==","SignatureSchemes":[1027,2052,1025,1283,2053,1281,2054,1537],"SupportedProtos":["h2","http/1.1"],"SupportedVersions":[6682,772,771],"RemoteAddr":{"IP":"10.212.134.205","Port":50584,"Zone":""},"LocalAddr":{"IP":"10.0.0.13","Port":443,"Zone":""}}}}
May 10 12:24:48 auth caddy[60234]: {"level":"debug","ts":1715358288.566787,"logger":"tls.handshake","msg":"no matching certificates and no custom selection logic","identifier":"smx"}
May 10 12:24:48 auth caddy[60234]: {"level":"debug","ts":1715358288.566793,"logger":"tls.handshake","msg":"no matching certificates and no custom selection logic","identifier":"*"}
May 10 12:24:48 auth caddy[60234]: {"level":"debug","ts":1715358288.5668101,"logger":"tls.handshake","msg":"no certificate matching TLS ClientHello","remote_ip":"10.212.134.205","remote_port":"50584","server_name":"smx","remote":"10.212.134.205:50584","identifier":"smx","cipher_suites":[19018,4865,4866,4867,49195,49199,49196,49200,52393,52392,49171,49172,156,157,47,53],"cert_cache_fill":0.0001,"load_or_obtain_if_necessary":true,"on_demand":false}
May 10 12:24:48 auth caddy[60234]: {"level":"debug","ts":1715358288.5668664,"logger":"http.stdlib","msg":"http: TLS handshake error from 10.212.134.205:50584: no certificate available for 'smx'"}
May 10 12:24:48 auth caddy[60234]: {"level":"debug","ts":1715358288.5716465,"logger":"events","msg":"event","name":"tls_get_certificate","id":"735775d0-2613-4a53-8ed7-af01ef329a69","origin":"tls","data":{"client_hello":{"CipherSuites":[31354,4865,4866,4867,49195,49199,49196,49200,52393,52392,49171,49172,156,157,47,53],"ServerName":"smx","SupportedCurves":[51914,25497,29,23,24],"SupportedPoints":"AA==","SignatureSchemes":[1027,2052,1025,1283,2053,1281,2054,1537],"SupportedProtos":["h2","http/1.1"],"SupportedVersions":[14906,772,771],"RemoteAddr":{"IP":"10.212.134.205","Port":50594,"Zone":""},"LocalAddr":{"IP":"10.0.0.13","Port":443,"Zone":""}}}}
May 10 12:24:48 auth caddy[60234]: {"level":"debug","ts":1715358288.571663,"logger":"tls.handshake","msg":"no matching certificates and no custom selection logic","identifier":"smx"}
May 10 12:24:48 auth caddy[60234]: {"level":"debug","ts":1715358288.5716693,"logger":"tls.handshake","msg":"no matching certificates and no custom selection logic","identifier":"*"}
May 10 12:24:48 auth caddy[60234]: {"level":"debug","ts":1715358288.571701,"logger":"tls.handshake","msg":"no certificate matching TLS ClientHello","remote_ip":"10.212.134.205","remote_port":"50594","server_name":"smx","remote":"10.212.134.205:50594","identifier":"smx","cipher_suites":[31354,4865,4866,4867,49195,49199,49196,49200,52393,52392,49171,49172,156,157,47,53],"cert_cache_fill":0.0001,"load_or_obtain_if_necessary":true,"on_demand":false}
May 10 12:24:48 auth caddy[60234]: {"level":"debug","ts":1715358288.5717356,"logger":"http.stdlib","msg":"http: TLS handshake error from 10.212.134.205:50594: no certificate available for 'smx'"}
May 10 12:24:57 auth caddy[60234]: {"level":"debug","ts":1715358297.9667902,"logger":"http.handlers.reverse_proxy","msg":"selected upstream","dial":"10.0.0.7:3443","total_upstreams":1}
May 10 12:24:57 auth caddy[60234]: {"level":"debug","ts":1715358297.9672012,"logger":"events","msg":"event","name":"tls_get_certificate","id":"a896d7f8-8fd3-4dea-bb2b-a41c0d806abc","origin":"tls","data":{"client_hello":{"CipherSuites":[4865,4866,4867],"ServerName":"smx.ecfinternal.net","SupportedCurves":[25497,29,23,24],"SupportedPoints":null,"SignatureSchemes":[1027,2052,1025,1283,2053,1281,2054,1537,513],"SupportedProtos":["h3"],"SupportedVersions":[772],"RemoteAddr":{"IP":"10.212.134.205","Port":34808,"Zone":""},"LocalAddr":{"IP":"10.0.0.13","Port":443,"Zone":""}}}}
May 10 12:24:57 auth caddy[60234]: {"level":"debug","ts":1715358297.967305,"logger":"tls.handshake","msg":"choosing certificate","identifier":"smx.ecfinternal.net","num_choices":1}
May 10 12:24:57 auth caddy[60234]: {"level":"debug","ts":1715358297.9673162,"logger":"tls.handshake","msg":"default certificate selection results","identifier":"smx.ecfinternal.net","subjects":["smx.ecfinternal.net"],"managed":true,"issuer_key":"acme-v02.api.letsencrypt.org-directory","hash":"4213fb41b0ff4968c1fa5ceeca03f28086fa3436aefc34b83437f3f247337a1e"}
May 10 12:24:57 auth caddy[60234]: {"level":"debug","ts":1715358297.9673212,"logger":"tls.handshake","msg":"matched certificate in cache","remote_ip":"10.212.134.205","remote_port":"34808","subjects":["smx.ecfinternal.net"],"managed":true,"expiration":1723130405,"hash":"4213fb41b0ff4968c1fa5ceeca03f28086fa3436aefc34b83437f3f247337a1e"}
May 10 12:24:57 auth caddy[60234]: {"level":"debug","ts":1715358297.968536,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip","upstream":"10.0.0.7:3443","duration":0.001274288,"request":{"remote_ip":"10.212.134.205","remote_port":"50578","client_ip":"10.212.134.205","proto":"HTTP/2.0","method":"GET","host":"smx.ecfinternal.net","uri":"/","headers":{"User-Agent":["Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/124.0.0.0 Safari/537.36"],"Sec-Fetch-Site":["none"],"X-Forwarded-Proto":["https"],"Sec-Fetch-Dest":["document"],"Accept":["text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,image/apng,*/*;q=0.8,application/signed-exchange;v=b3;q=0.7"],"Sec-Ch-Ua-Mobile":["?0"],"Priority":["u=0, i"],"Sec-Ch-Ua-Platform":["\"Linux\""],"Sec-Fetch-Mode":["navigate"],"Accept-Language":["en-US,en;q=0.9"],"X-Forwarded-For":["10.212.134.205"],"X-Forwarded-Host":["smx.ecfinternal.net"],"Sec-Ch-Ua":["\"Chromium\";v=\"124\", \"Google Chrome\";v=\"124\", \"Not-A.Brand\";v=\"99\""],"Sec-Fetch-User":["?1"],"Upgrade-Insecure-Requests":["1"],"Accept-Encoding":["gzip, deflate, br"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"smx.ecfinternal.net"}},"error":"tls: failed to verify certificate: x509: cannot validate certificate for 10.0.0.7 because it doesn't contain any IP SANs"}
May 10 12:24:57 auth caddy[60234]: {"level":"error","ts":1715358297.9685853,"logger":"http.log.error","msg":"tls: failed to verify certificate: x509: cannot validate certificate for 10.0.0.7 because it doesn't contain any IP SANs","request":{"remote_ip":"10.212.134.205","remote_port":"50578","client_ip":"10.212.134.205","proto":"HTTP/2.0","method":"GET","host":"smx.ecfinternal.net","uri":"/","headers":{"Sec-Fetch-Mode":["navigate"],"Sec-Fetch-User":["?1"],"Sec-Fetch-Dest":["document"],"Sec-Ch-Ua":["\"Chromium\";v=\"124\", \"Google Chrome\";v=\"124\", \"Not-A.Brand\";v=\"99\""],"Sec-Ch-Ua-Platform":["\"Linux\""],"Accept":["text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,image/apng,*/*;q=0.8,application/signed-exchange;v=b3;q=0.7"],"Sec-Fetch-Site":["none"],"Accept-Encoding":["gzip, deflate, br"],"Accept-Language":["en-US,en;q=0.9"],"Priority":["u=0, i"],"Sec-Ch-Ua-Mobile":["?0"],"Upgrade-Insecure-Requests":["1"],"User-Agent":["Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/124.0.0.0 Safari/537.36"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"smx.ecfinternal.net"}},"duration":0.001839034,"status":502,"err_id":"sazi9w73t","err_trace":"reverseproxy.statusError (reverseproxy.go:1269)"}
Changing the ip in address in the caddy file from https://10.0.0.7:3443 to 10.0.0.7:3443 seems to have resolved this error “509: cannot validate certificate for 10.0.0.7 because it doesn’t contain any IP SANs”,“request”
Updated logs with that change:
May 10 12:36:22 auth systemd[1]: Started Caddy.
May 10 12:36:22 auth caddy[60311]: {"level":"info","ts":1715358982.5107865,"logger":"tls.obtain","msg":"acquiring lock","identifier":"smx.ecfinternal.net"}
May 10 12:36:22 auth caddy[60311]: {"level":"info","ts":1715358982.5138905,"logger":"tls","msg":"cleaning storage unit","storage":"FileStorage:/var/lib/caddy/.local/share/caddy"}
May 10 12:36:22 auth caddy[60311]: {"level":"info","ts":1715358982.5147436,"logger":"tls","msg":"finished cleaning storage units"}
May 10 12:36:22 auth caddy[60311]: {"level":"info","ts":1715358982.5156076,"logger":"tls.obtain","msg":"lock acquired","identifier":"smx.ecfinternal.net"}
May 10 12:36:22 auth caddy[60311]: {"level":"info","ts":1715358982.5158136,"logger":"tls.obtain","msg":"obtaining certificate","identifier":"smx.ecfinternal.net"}
May 10 12:36:22 auth caddy[60311]: {"level":"debug","ts":1715358982.5159392,"logger":"events","msg":"event","name":"cert_obtaining","id":"a79219cb-7beb-4fc8-9a00-419de11f3b72","origin":"tls","data":{"identifier":"smx.ecfinternal.net"}}
May 10 12:36:22 auth caddy[60311]: {"level":"debug","ts":1715358982.516185,"logger":"tls.obtain","msg":"trying issuer 1/2","issuer":"acme-v02.api.letsencrypt.org-directory"}
May 10 12:36:22 auth caddy[60311]: {"level":"debug","ts":1715358982.7122438,"logger":"tls.issuance.acme.acme_client","msg":"http request","method":"GET","url":"https://acme-v02.api.letsencrypt.org/directory","headers":{"User-Agent":["Caddy/2.8.0-beta.2 CertMagic acmez (linux; amd64)"]},"response_headers":{"Cache-Control":["public, max-age=0, no-cache"],"Content-Length":["747"],"Content-Type":["application/json"],"Date":["Fri, 10 May 2024 16:36:22 GMT"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]},"status_code":200}
May 10 12:36:22 auth caddy[60311]: {"level":"debug","ts":1715358982.769612,"logger":"tls.issuance.acme.acme_client","msg":"http request","method":"HEAD","url":"https://acme-v02.api.letsencrypt.org/acme/new-nonce","headers":{"User-Agent":["Caddy/2.8.0-beta.2 CertMagic acmez (linux; amd64)"]},"response_headers":{"Cache-Control":["public, max-age=0, no-cache"],"Date":["Fri, 10 May 2024 16:36:22 GMT"],"Link":["<https://acme-v02.api.letsencrypt.org/directory>;rel=\"index\""],"Replay-Nonce":["6Jd4kJYiyBBbRF68iMljagb09W9wPqas8ZbXeuKOPoGylh0H7ck"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]},"status_code":200}
May 10 12:36:22 auth caddy[60311]: {"level":"debug","ts":1715358982.8374035,"logger":"tls.issuance.acme.acme_client","msg":"http request","method":"POST","url":"https://acme-v02.api.letsencrypt.org/acme/new-acct","headers":{"Content-Type":["application/jose+json"],"User-Agent":["Caddy/2.8.0-beta.2 CertMagic acmez (linux; amd64)"]},"response_headers":{"Boulder-Requester":["1719494907"],"Cache-Control":["public, max-age=0, no-cache"],"Content-Length":["326"],"Content-Type":["application/json"],"Date":["Fri, 10 May 2024 16:36:22 GMT"],"Link":["<https://acme-v02.api.letsencrypt.org/directory>;rel=\"index\"","<https://letsencrypt.org/documents/LE-SA-v1.4-April-3-2024.pdf>;rel=\"terms-of-service\""],"Location":["https://acme-v02.api.letsencrypt.org/acme/acct/1719494907"],"Replay-Nonce":["6Jd4kJYib1LZWspdyazU5JWkQl0pBv4cFWuhTU9svNudxUJfQLc"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]},"status_code":201}
May 10 12:36:22 auth caddy[60311]: {"level":"info","ts":1715358982.83774,"logger":"tls.issuance.acme","msg":"waiting on internal rate limiter","identifiers":["smx.ecfinternal.net"],"ca":"https://acme-v02.api.letsencrypt.org/directory","account":"my@email.net"}
May 10 12:36:22 auth caddy[60311]: {"level":"info","ts":1715358982.8377526,"logger":"tls.issuance.acme","msg":"done waiting on internal rate limiter","identifiers":["smx.ecfinternal.net"],"ca":"https://acme-v02.api.letsencrypt.org/directory","account":"my@email.net"}
May 10 12:36:22 auth caddy[60311]: {"level":"info","ts":1715358982.8377883,"logger":"tls.issuance.acme","msg":"using ACME account","account_id":"https://acme-v02.api.letsencrypt.org/acme/acct/1719494907","account_contact":["mailto:my@email.net"]}
May 10 12:36:22 auth caddy[60311]: {"level":"debug","ts":1715358982.8377948,"logger":"tls.issuance.acme.acme_client","msg":"creating order","account":"https://acme-v02.api.letsencrypt.org/acme/acct/1719494907","identifiers":["smx.ecfinternal.net"]}
May 10 12:36:22 auth caddy[60311]: {"level":"debug","ts":1715358982.9327738,"logger":"tls.issuance.acme.acme_client","msg":"http request","method":"POST","url":"https://acme-v02.api.letsencrypt.org/acme/new-order","headers":{"Content-Type":["application/jose+json"],"User-Agent":["Caddy/2.8.0-beta.2 CertMagic acmez (linux; amd64)"]},"response_headers":{"Boulder-Requester":["1719494907"],"Cache-Control":["public, max-age=0, no-cache"],"Content-Length":["345"],"Content-Type":["application/json"],"Date":["Fri, 10 May 2024 16:36:22 GMT"],"Link":["<https://acme-v02.api.letsencrypt.org/directory>;rel=\"index\""],"Location":["https://acme-v02.api.letsencrypt.org/acme/order/1719494907/268245839177"],"Replay-Nonce":["6Jd4kJYiYMgipDZ8s-JvE-OiWcPUNirTDcZn0G7lAxrsxHYthnM"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]},"status_code":201}
May 10 12:36:22 auth caddy[60311]: {"level":"debug","ts":1715358982.9941964,"logger":"tls.issuance.acme.acme_client","msg":"http request","method":"POST","url":"https://acme-v02.api.letsencrypt.org/acme/authz-v3/349084162957","headers":{"Content-Type":["application/jose+json"],"User-Agent":["Caddy/2.8.0-beta.2 CertMagic acmez (linux; amd64)"]},"response_headers":{"Boulder-Requester":["1719494907"],"Cache-Control":["public, max-age=0, no-cache"],"Content-Length":["803"],"Content-Type":["application/json"],"Date":["Fri, 10 May 2024 16:36:22 GMT"],"Link":["<https://acme-v02.api.letsencrypt.org/directory>;rel=\"index\""],"Replay-Nonce":["7n34iCGfUyD04oLg7JJ4c7Pi0dQ4Zy979Wv_kfdfr4cjIYuoUOI"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]},"status_code":200}
May 10 12:36:22 auth caddy[60311]: {"level":"debug","ts":1715358982.994358,"logger":"tls.issuance.acme.acme_client","msg":"no solver configured","challenge_type":"http-01"}
May 10 12:36:22 auth caddy[60311]: {"level":"debug","ts":1715358982.9943664,"logger":"tls.issuance.acme.acme_client","msg":"no solver configured","challenge_type":"tls-alpn-01"}
May 10 12:36:22 auth caddy[60311]: {"level":"info","ts":1715358982.9943707,"logger":"tls.issuance.acme.acme_client","msg":"trying to solve challenge","identifier":"smx.ecfinternal.net","challenge_type":"dns-01","ca":"https://acme-v02.api.letsencrypt.org/directory"}
May 10 12:36:23 auth caddy[60311]: {"level":"debug","ts":1715358983.5701804,"logger":"tls.issuance.acme.acme_client","msg":"waiting for solver before continuing","identifier":"smx.ecfinternal.net","challenge_type":"dns-01"}
May 10 12:36:30 auth caddy[60311]: {"level":"debug","ts":1715358990.089698,"logger":"events","msg":"event","name":"tls_get_certificate","id":"3f541184-2d65-4ac4-98c5-31a21f7fc666","origin":"tls","data":{"client_hello":{"CipherSuites":[4866,4867,4865,49196,49200,159,52393,52392,52394,49195,49199,158,49188,49192,107,49187,49191,103,49162,49172,57,49161,49171,51,157,156,61,60,53,47,255],"ServerName":"smx.ecfinternal.net","SupportedCurves":[29,23,30,25,24,256,257,258,259,260],"SupportedPoints":"AAEC","SignatureSchemes":[1027,1283,1539,2055,2056,2057,2058,2059,2052,2053,2054,1025,1281,1537,771,769,770,1026,1282,1538],"SupportedProtos":["h2","http/1.1"],"SupportedVersions":[772,771],"RemoteAddr":{"IP":"10.0.0.13","Port":60838,"Zone":""},"LocalAddr":{"IP":"10.0.0.13","Port":443,"Zone":""}}}}
May 10 12:36:30 auth caddy[60311]: {"level":"debug","ts":1715358990.0897295,"logger":"tls.handshake","msg":"no matching certificates and no custom selection logic","identifier":"smx.ecfinternal.net"}
May 10 12:36:30 auth caddy[60311]: {"level":"debug","ts":1715358990.089735,"logger":"tls.handshake","msg":"no matching certificates and no custom selection logic","identifier":"*.ecfinternal.net"}
May 10 12:36:30 auth caddy[60311]: {"level":"debug","ts":1715358990.0897374,"logger":"tls.handshake","msg":"no matching certificates and no custom selection logic","identifier":"*.*.net"}
May 10 12:36:30 auth caddy[60311]: {"level":"debug","ts":1715358990.0897408,"logger":"tls.handshake","msg":"no matching certificates and no custom selection logic","identifier":"*.*.*"}
May 10 12:36:30 auth caddy[60311]: {"level":"debug","ts":1715358990.089754,"logger":"tls.handshake","msg":"no certificate matching TLS ClientHello","remote_ip":"10.0.0.13","remote_port":"60838","server_name":"smx.ecfinternal.net","remote":"10.0.0.13:60838","identifier":"smx.ecfinternal.net","cipher_suites":[4866,4867,4865,49196,49200,159,52393,52392,52394,49195,49199,158,49188,49192,107,49187,49191,103,49162,49172,57,49161,49171,51,157,156,61,60,53,47,255],"cert_cache_fill":0,"load_or_obtain_if_necessary":true,"on_demand":false}
May 10 12:36:30 auth caddy[60311]: {"level":"debug","ts":1715358990.0909655,"logger":"http.stdlib","msg":"http: TLS handshake error from 10.0.0.13:60838: no certificate available for 'smx.ecfinternal.net'"}
May 10 12:36:37 auth caddy[60311]: {"level":"debug","ts":1715358997.9496508,"logger":"tls.issuance.acme.acme_client","msg":"done waiting for solver","identifier":"smx.ecfinternal.net","challenge_type":"dns-01"}
May 10 12:36:38 auth caddy[60311]: {"level":"debug","ts":1715358998.0122943,"logger":"tls.issuance.acme.acme_client","msg":"http request","method":"POST","url":"https://acme-v02.api.letsencrypt.org/acme/chall-v3/349084162957/zmRofw","headers":{"Content-Type":["application/jose+json"],"User-Agent":["Caddy/2.8.0-beta.2 CertMagic acmez (linux; amd64)"]},"response_headers":{"Boulder-Requester":["1719494907"],"Cache-Control":["public, max-age=0, no-cache"],"Content-Length":["186"],"Content-Type":["application/json"],"Date":["Fri, 10 May 2024 16:36:37 GMT"],"Link":["<https://acme-v02.api.letsencrypt.org/directory>;rel=\"index\"","<https://acme-v02.api.letsencrypt.org/acme/authz-v3/349084162957>;rel=\"up\""],"Location":["https://acme-v02.api.letsencrypt.org/acme/chall-v3/349084162957/zmRofw"],"Replay-Nonce":["7n34iCGfBrzisJWbB7IkM0bGnkEriw0Vo05WDnejr5qqBcRaEws"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]},"status_code":200}
May 10 12:36:38 auth caddy[60311]: {"level":"debug","ts":1715358998.0123484,"logger":"tls.issuance.acme.acme_client","msg":"challenge accepted","identifier":"smx.ecfinternal.net","challenge_type":"dns-01"}
May 10 12:36:38 auth caddy[60311]: {"level":"debug","ts":1715358998.3232245,"logger":"tls.issuance.acme.acme_client","msg":"http request","method":"POST","url":"https://acme-v02.api.letsencrypt.org/acme/authz-v3/349084162957","headers":{"Content-Type":["application/jose+json"],"User-Agent":["Caddy/2.8.0-beta.2 CertMagic acmez (linux; amd64)"]},"response_headers":{"Boulder-Requester":["1719494907"],"Cache-Control":["public, max-age=0, no-cache"],"Content-Length":["513"],"Content-Type":["application/json"],"Date":["Fri, 10 May 2024 16:36:38 GMT"],"Link":["<https://acme-v02.api.letsencrypt.org/directory>;rel=\"index\""],"Replay-Nonce":["7n34iCGfMSmrRAVjJeE5KSo0FlvHcJ4ubAyaxagzaJMFIxtSPUQ"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]},"status_code":200}
May 10 12:36:39 auth caddy[60311]: {"level":"info","ts":1715358999.705626,"logger":"tls.issuance.acme.acme_client","msg":"authorization finalized","identifier":"smx.ecfinternal.net","authz_status":"valid"}
May 10 12:36:39 auth caddy[60311]: {"level":"info","ts":1715358999.705653,"logger":"tls.issuance.acme.acme_client","msg":"validations succeeded; finalizing order","order":"https://acme-v02.api.letsencrypt.org/acme/order/1719494907/268245839177"}
May 10 12:36:40 auth caddy[60311]: {"level":"debug","ts":1715359000.0214741,"logger":"tls.issuance.acme.acme_client","msg":"http request","method":"POST","url":"https://acme-v02.api.letsencrypt.org/acme/finalize/1719494907/268245839177","headers":{"Content-Type":["application/jose+json"],"User-Agent":["Caddy/2.8.0-beta.2 CertMagic acmez (linux; amd64)"]},"response_headers":{"Boulder-Requester":["1719494907"],"Cache-Control":["public, max-age=0, no-cache"],"Content-Length":["447"],"Content-Type":["application/json"],"Date":["Fri, 10 May 2024 16:36:39 GMT"],"Link":["<https://acme-v02.api.letsencrypt.org/directory>;rel=\"index\""],"Location":["https://acme-v02.api.letsencrypt.org/acme/order/1719494907/268245839177"],"Replay-Nonce":["6Jd4kJYi5vLi197JJYHFqwfVCldlVpoCsUX2n1z3qRYko0OPlNU"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]},"status_code":200}
May 10 12:36:40 auth caddy[60311]: {"level":"debug","ts":1715359000.0817506,"logger":"tls.issuance.acme.acme_client","msg":"http request","method":"POST","url":"https://acme-v02.api.letsencrypt.org/acme/cert/03a8d230315f5098b71d2d8b2a27e5a72ce4","headers":{"Content-Type":["application/jose+json"],"User-Agent":["Caddy/2.8.0-beta.2 CertMagic acmez (linux; amd64)"]},"response_headers":{"Cache-Control":["public, max-age=0, no-cache"],"Content-Length":["3328"],"Content-Type":["application/pem-certificate-chain"],"Date":["Fri, 10 May 2024 16:36:40 GMT"],"Link":["<https://acme-v02.api.letsencrypt.org/directory>;rel=\"index\"","<https://acme-v02.api.letsencrypt.org/acme/cert/03a8d230315f5098b71d2d8b2a27e5a72ce4/1>;rel=\"alternate\""],"Replay-Nonce":["6Jd4kJYimZZvYLkJ5i8K1sXwoZOAi0UAq9tJPsytnAHLXYbAEBc"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]},"status_code":200}
May 10 12:36:40 auth caddy[60311]: {"level":"debug","ts":1715359000.0818446,"logger":"tls.issuance.acme.acme_client","msg":"getting renewal info","names":["smx.ecfinternal.net"]}
May 10 12:36:40 auth caddy[60311]: {"level":"debug","ts":1715359000.2042205,"logger":"tls.issuance.acme.acme_client","msg":"http request","method":"GET","url":"https://acme-v02.api.letsencrypt.org/draft-ietf-acme-ari-02/renewalInfo//FC6zF7dYVsuuUAlA5h-vnYsUwsY.A6jSMDFfUJi3HS2LKiflpyzk","headers":{"User-Agent":["Caddy/2.8.0-beta.2 CertMagic acmez (linux; amd64)"]},"response_headers":{"Cache-Control":["public, max-age=0, no-cache"],"Content-Length":["101"],"Content-Type":["application/json"],"Date":["Fri, 10 May 2024 16:36:40 GMT"],"Link":["<https://acme-v02.api.letsencrypt.org/directory>;rel=\"index\""],"Retry-After":["21600"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]},"status_code":200}
May 10 12:36:40 auth caddy[60311]: {"level":"info","ts":1715359000.2043173,"logger":"tls.issuance.acme.acme_client","msg":"got renewal info","names":["smx.ecfinternal.net"],"window_start":1720454198,"window_end":1720626998,"selected_time":1720611060,"recheck_after":1715380600.20431,"explanation_url":""}
May 10 12:36:40 auth caddy[60311]: {"level":"debug","ts":1715359000.266312,"logger":"tls.issuance.acme.acme_client","msg":"http request","method":"POST","url":"https://acme-v02.api.letsencrypt.org/acme/cert/03a8d230315f5098b71d2d8b2a27e5a72ce4/1","headers":{"Content-Type":["application/jose+json"],"User-Agent":["Caddy/2.8.0-beta.2 CertMagic acmez (linux; amd64)"]},"response_headers":{"Cache-Control":["public, max-age=0, no-cache"],"Content-Length":["5252"],"Content-Type":["application/pem-certificate-chain"],"Date":["Fri, 10 May 2024 16:36:40 GMT"],"Link":["<https://acme-v02.api.letsencrypt.org/directory>;rel=\"index\"","<https://acme-v02.api.letsencrypt.org/acme/cert/03a8d230315f5098b71d2d8b2a27e5a72ce4/0>;rel=\"alternate\""],"Replay-Nonce":["7n34iCGf81EhXGUpW5e_umeZZvdleLGgPgSySSbi-ZBHsLexJrg"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]},"status_code":200}
May 10 12:36:40 auth caddy[60311]: {"level":"debug","ts":1715359000.2664828,"logger":"tls.issuance.acme.acme_client","msg":"getting renewal info","names":["smx.ecfinternal.net"]}
May 10 12:36:40 auth caddy[60311]: {"level":"debug","ts":1715359000.3878896,"logger":"tls.issuance.acme.acme_client","msg":"http request","method":"GET","url":"https://acme-v02.api.letsencrypt.org/draft-ietf-acme-ari-02/renewalInfo//FC6zF7dYVsuuUAlA5h-vnYsUwsY.A6jSMDFfUJi3HS2LKiflpyzk","headers":{"User-Agent":["Caddy/2.8.0-beta.2 CertMagic acmez (linux; amd64)"]},"response_headers":{"Cache-Control":["public, max-age=0, no-cache"],"Content-Length":["101"],"Content-Type":["application/json"],"Date":["Fri, 10 May 2024 16:36:40 GMT"],"Link":["<https://acme-v02.api.letsencrypt.org/directory>;rel=\"index\""],"Retry-After":["21600"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]},"status_code":200}
May 10 12:36:40 auth caddy[60311]: {"level":"info","ts":1715359000.3879347,"logger":"tls.issuance.acme.acme_client","msg":"got renewal info","names":["smx.ecfinternal.net"],"window_start":1720454198,"window_end":1720626998,"selected_time":1720472714,"recheck_after":1715380600.387932,"explanation_url":""}
May 10 12:36:40 auth caddy[60311]: {"level":"info","ts":1715359000.387961,"logger":"tls.issuance.acme.acme_client","msg":"successfully downloaded available certificate chains","count":2,"first_url":"https://acme-v02.api.letsencrypt.org/acme/cert/03a8d230315f5098b71d2d8b2a27e5a72ce4"}
May 10 12:36:40 auth caddy[60311]: {"level":"debug","ts":1715359000.3879669,"logger":"tls.issuance.acme","msg":"selected certificate chain","url":"https://acme-v02.api.letsencrypt.org/acme/cert/03a8d230315f5098b71d2d8b2a27e5a72ce4"}
May 10 12:36:40 auth caddy[60311]: {"level":"info","ts":1715359000.388351,"logger":"tls.obtain","msg":"certificate obtained successfully","identifier":"smx.ecfinternal.net","issuer":"acme-v02.api.letsencrypt.org-directory"}
May 10 12:36:40 auth caddy[60311]: {"level":"debug","ts":1715359000.3884315,"logger":"events","msg":"event","name":"cert_obtained","id":"d3506deb-7692-47a8-a9fe-f69409a7835b","origin":"tls","data":{"certificate_path":"certificates/acme-v02.api.letsencrypt.org-directory/smx.ecfinternal.net/smx.ecfinternal.net.crt","csr_pem":"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","identifier":"smx.ecfinternal.net","issuer":"acme-v02.api.letsencrypt.org-directory","metadata_path":"certificates/acme-v02.api.letsencrypt.org-directory/smx.ecfinternal.net/smx.ecfinternal.net.json","private_key_path":"certificates/acme-v02.api.letsencrypt.org-directory/smx.ecfinternal.net/smx.ecfinternal.net.key","renewal":false,"storage_path":"certificates/acme-v02.api.letsencrypt.org-directory/smx.ecfinternal.net"}}
May 10 12:36:40 auth caddy[60311]: {"level":"info","ts":1715359000.3884375,"logger":"tls.obtain","msg":"releasing lock","identifier":"smx.ecfinternal.net"}
May 10 12:36:40 auth caddy[60311]: {"level":"debug","ts":1715359000.38866,"logger":"tls","msg":"loading managed certificate","domain":"smx.ecfinternal.net","expiration":1723131399,"issuer_key":"acme-v02.api.letsencrypt.org-directory","storage":"FileStorage:/var/lib/caddy/.local/share/caddy"}
May 10 12:36:40 auth caddy[60311]: {"level":"debug","ts":1715359000.4935892,"logger":"tls.cache","msg":"added certificate to cache","subjects":["smx.ecfinternal.net"],"expiration":1723131399,"managed":true,"issuer_key":"acme-v02.api.letsencrypt.org-directory","hash":"e4680313aa8bd1f815b9be672437439d142423bd42218a5b2b77b7fbbe2d4d03","cache_size":1,"cache_capacity":10000}
May 10 12:36:40 auth caddy[60311]: {"level":"debug","ts":1715359000.4936144,"logger":"events","msg":"event","name":"cached_managed_cert","id":"c0642447-5eca-4317-81e8-09a10de93e91","origin":"tls","data":{"sans":["smx.ecfinternal.net"]}}
* Trying 10.0.0.13:443...
* ALPN, offering h2
* start date: May 10 15:36:39 2024 GMT
* expire date: Aug 8 15:36:38 2024 GMT
* Using Stream ID: 1 (easy handle 0x558ea4206eb0)
> GET / HTTP/2
> accept: */*
< HTTP/2 502
< server: Caddy
< content-length: 0
< date: Fri, 10 May 2024 16:40:52 GMT
