For most of my usage of Caddy, I reverse_proxy to localhost for containers. Simple enough, and I can just use http as its all internal to the machine. I’ve recently expanded my “fleet” a little bit, so to speak, and want one of my containers (and subsequently, domains) to run on a different machine. In other words:
domain (WAN) → router (port forward) → server with caddy (reverse proxies a specific subdomain) → another machine with caddy listening on port 443
Higher security is needed for this service, and as such I am not willing for mere HTTP traffic across the LAN, hence my conundrum of requiring HTTPS between the two machines.
Here is what caddy logs when a new connection to this domain is attempted.
Feb 06 23:38:01 centauri caddy[1401534]: {"level":"error","ts":1738913881.234303,"logger":"http.log.error","msg":"remote error: tls: internal error","request":{"remote_ip":"<IP>","remote_port":"39012","client_ip":"<IP>","proto":"HTTP/2.0","method":"GET","host":"<DOMAIN>","uri":"/","headers":{"Accept-Language":["en-US,en;q=0.5"],"Upgrade-Insecure-Requests":["1"],"Sec-Fetch-Dest":["document"],"Sec-Fetch-Site":["none"],"User-Agent":["Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:134.0) Gecko/20100101 Firefox/134.0"],"Accept-Encoding":["gzip, deflate, br, zstd"],"Dnt":["1"],"Sec-Gpc":["1"],"Sec-Fetch-Mode":["navigate"],"Sec-Fetch-User":["?1"],"Priority":["u=0, i"],"Te":["trailers"],"Accept":["text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"<DOMAIN>"}},"duration":0.018268014,"status":502,"err_id":"nvx8rg4rt","err_trace":"reverseproxy.statusError (reverseproxy.go:1269)"}
Feb 06 23:38:01 centauri caddy[1401534]: {"level":"error","ts":1738913881.6438465,"logger":"http.log.error","msg":"remote error: tls: internal error","request":{"remote_ip":"<IP>","remote_port":"39012","client_ip":"<IP>","proto":"HTTP/2.0","method":"GET","host":"<DOMAIN>","uri":"/favicon.ico","headers":{"Accept-Language":["en-US,en;q=0.5"],"Sec-Fetch-Mode":["no-cors"],"Priority":["u=6"],"Sec-Fetch-Dest":["image"],"Sec-Fetch-Site":["same-origin"],"User-Agent":["Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:134.0) Gecko/20100101 Firefox/134.0"],"Accept":["image/avif,image/webp,image/png,image/svg+xml,image/*;q=0.8,*/*;q=0.5"],"Accept-Encoding":["gzip, deflate, br, zstd"],"Dnt":["1"],"Sec-Gpc":["1"],"Referer":["https://<DOMAIN>/favicon.ico"],"Te":["trailers"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"<DOMAIN>"}},"duration":0.027526728,"status":502,"err_id":"4wg8udbw4","err_trace":"reverseproxy.statusError (reverseproxy.go:1269)"}
Here are some log lines from the secondary machine (likely unhelpful, just shows the SSL challenge is failing, and I’m pretty sure all the issues are with the primary server config).
Feb 06 23:32:25 alpha caddy[176926]: {"level":"error","ts":1738913545.6700125,"logger":"http.acme_client","msg":"challenge failed","identifier":"<DOMAIN>","challenge_type":"tls-alpn-01","problem":{"type":"urn:ietf:params:acme:error:tls","title":"","detail":"<DOMAIN IP>: remote error: tls: internal error","instance":"","subproblems":[]}}
Feb 06 23:32:25 alpha caddy[176926]: {"level":"error","ts":1738913545.6700525,"logger":"http.acme_client","msg":"validating authorization","identifier":"<DOMAIN>","problem":{"type":"urn:ietf:params:acme:error:tls","title":"","detail":"<DOMAIN IP>: remote error: tls: internal error","instance":"","subproblems":[]},"order":"https://acme-staging-v02.api.letsencrypt.org/acme/order/183808574/22459095454","attempt":2,"max_attempts":3}
Feb 06 23:32:25 alpha caddy[176926]: {"level":"error","ts":1738913545.6700685,"logger":"tls.obtain","msg":"could not get certificate from issuer","identifier":"<DOMAIN>","issuer":"acme-v02.api.letsencrypt.org-directory","error":"HTTP 400 urn:ietf:params:acme:error:tls - <DOMAIN IP>: remote error: tls: internal error"}
Feb 06 23:32:25 alpha caddy[176926]: {"level":"error","ts":1738913545.6701024,"logger":"tls.obtain","msg":"will retry","error":"[<DOMAIN>] Obtain: [<DOMAIN>] solving challenge: <DOMAIN>: [<DOMAIN>] authorization failed: HTTP 400 urn:ietf:params:acme:error:tls - <DOMAIN IP>: remote error: tls: internal error (ca=https://acme-staging-v02.api.letsencrypt.org/directory)","attempt":5,"retrying_in":600,"elapsed":612.420105734,"max_duration":2592000}
2.8.4 on both machines (Fedora 41 latest package)
Fedora 41, x86_64, systemd, native package
systemctl start caddy
I’m just using what shipped with the OS.
# caddy.service
Description=Caddy web server
After=network.target
Type=notify
ExecStartPre=/usr/bin/caddy validate --config /etc/caddy/Caddyfile
ProtectHome=true
I cannot provide the subdomain for this service. If I could help it, it wouldn’t even be internet facing, but here we are. I’ve tried both of the following files on the main (internet facing) caddy instance:
https://<DOMAIN>:443 {
reverse_proxy https://<LAN IP (secondary)>:443
reverse_proxy https://<LAN IP (secondary)>:443 {
header_up Host {header.X-Forwarded-Host}
header_up X-Forwarded-Host {Host}
And for the secondary (LAN only) caddy instance (this is effectively what the primary server used to have):
reverse_proxy 10.88.0.1:10007
All <DOMAIN>
strings match - I’m not that stupid.
