I want to use reverse_proxy
, but require a static Authorization header for a route,
e.g. /abc should require Authorization: 123
e.g. /def should require Authorization: 456
and be forwarded upstream
otherwise status 401
like
@abc {
header Authorization 123
@def {
header Authorization 456
reverse_proxy @abc localhost:9000
reverse_proxy @def localhost:9000
respond 401
but I want to configure reverse_proxy
, and I dont want to repeat this following block for every route. Is there a way to basically name an upstream block (reverse_proxy
) and then reuse it?
I was thinking about listening locally :4000
and then use localhost:4000
as a shared target. But it adds unnecessary overhead.
reverse_proxy {
to server1:3000 server2:3000
lb_policy random
health_port 3000
health_interval 1s
health_passes 1
health_fails 10
health_timeout 5s
lb_retries 3
lb_try_duration 10s
header_down -X-Powered-By
# tls
# tls_client_auth
