Hi,
following up on a similar question.
In my case I will like to restrict only for a path
example.com {
@allowed remote_ip 11.11.11.11 22.22.22.22 33.33.33.33
handle @allowed /api/ {
reverse_proxy myapp:8080
# Fallback for otherwise not matched handles
abort
would the above work??
Please fill out the help topic template, as per the forum rules.
And please mind your post formatting, it’s very hard to read your config because you didn’t use code blocks.
system
(system)
Closed
3
