Win Server 2019
C:\caddy2> caddy run --watch
None
(add_custom_ssl_certificate) {
tls C:\caddy2\ssl\star_imperial_edu_2022-2023.crt C:\caddy2\ssl\star_imperial_edu_2022-2023.key
(add_logging_with_path) {
output file "{args.0}" {
roll_size 100mb
roll_keep 5
roll_keep_for 720h
format json
#format console
#format single_field common_log
appnavt.imperial.edu {
reverse_proxy http://v5nav.imperial.edu:8080
# Imports:
import add_custom_ssl_certificate
import add_logging_with_path "C:\caddy2\logs\appnavt_imperial_edu_access.log"
I want to restrict access to appnavt.imperial.edu to certain set of public IP addresses using remote_ip.
Where and how does remote_ip get coded for reverse_proxy shown? How to debug IP’s that are being filtered or allowed?
