See #2
docker-compose.yml
version: "3.1"
image: caddy/caddy:2.2.1-alpine
- ./etc/caddy/Caddyfile:/etc/caddy/Caddyfile
- ./.caddy/data:/data
- ./.caddy/config:/config
www:
image: demos/hello:plain-text
hostname: www.watheia.dev
container_name: hello-app
depends_on:
- caddy
etc/caddy/Cadyfile
# Optional email key for lets encrypt
email admin@watheia.dev
# Optional staging lets encrypt for testing. Comment out for production.
www.watheia.dev {
reverse_proxy / www:80
netdata.watheia.dev {
reverse_proxy / http://128.199.11.45:19999
Linux 5.4.0-51-generic amd64
docker-compose up -d
paste full file contents here
I am having trouble figuring out random strange behavior when serving standard web containers behind reverse proxy. For example:
Simple hello world is fine.
But then…
Default create-react-app loads with a blank manifest.json, even though the file exists in the container.
Also…
http://128.199.11.45:19999/ (this is fine)
https://netdata.watheia.dev/ (this loads a bunch of blank files)
There are no actual network errors being reported, so I’m not sure how to go about debugging the issue.
