Installed from PPA following steps in:
Ubuntu 20.04 in DigitalOcean (Fresh new droplet created on July 26th (Yesterday)
caddy start after setting up the Caddyserver file
somesite.com {
# Set this path to your site’s directory.
tls somemeial@gmail.com
root * /var/www/somefolder
encode gzip zstd
try_files {path} {path}/index.php
php_fastcgi localhost:9000
# The Caddyfile — Caddy Documentation
@cachedFiles {
path *.ico *.css *.js *.gif *.jpg *.jpeg *.png *.svg *.woff
header @cachedFiles Cache-Control max-age=5184000
Before running caddy I installed php7.4 and php7.4-fpm and then configured the www.conf file so it uses the port 9000 to listen. After that I ran caddy with the Caddyfile configuration above.
Paste config here, replacing this text.
LEAVE DOMAIN NAMES INTACT.
After the above, about 1 to 2 hours after install the bitcoin miner kinsing started.
Currently this happened before in Digitalocean with other tools installed, but this is the first time I have gotten to only doing very few things:
- Create the digitalocean droplet using Ubuntu 20.04
- Installed php7.4 and php7.4-fpm
- Installed caddy from PPA
- Configured Caddyfile and started the service
That was all. Is kinsing able to use or infect golang now?
