Hi there
I am trying to get my Caddyfile to handle my domain in such a way that the root displays a static html file, and the subdomain shows .txt files.
I have gotten api.dbam.dev
to serve these .txt files successfully using caddy file-server --root ~/DBAM/api/ --domain api.dbam.dev
as a standalone command. (example txt)
My issue is, when I try to replicate this in a Caddyfile so that i can have the subdomain api.
point to the directory with the txt files, and the root domain dbam.dev
point to the /www
directory, I am just met with 404 errors when requesting anything (even with the same file path as shown in example txt)
here is my Caddyfile as is;
dbam.dev {
root * /DBAM/www
file_server {
index index.html
browse
api.dbam.dev {
root * /DBAM/api
Logged output on caddy start
root@ubuntu-20:~/DBAM# caddy start
2021/08/08 13:25:34.714 INFO using adjacent Caddyfile
2021/08/08 13:25:34.716 WARN input is not formatted with 'caddy fmt' {"adapter": "caddyfile", "file": "Caddyfile", "line": 2}
2021/08/08 13:25:34.719 INFO admin admin endpoint started {"address": "tcp/localhost:2019", "enforce_origin": false, "origins": ["localhost:2019", "[::1]:2019", "127.0.0.1:2019"]}
2021/08/08 13:25:34.720 INFO http server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS {"server_name": "srv0", "https_port": 443}
2021/08/08 13:25:34.721 INFO http enabling automatic HTTP->HTTPS redirects {"server_name": "srv0"}
2021/08/08 13:25:34.722 INFO http enabling automatic TLS certificate management {"domains": ["api.dbam.dev", "dbam.dev"]}
2021/08/08 13:25:34.731 INFO tls.cache.maintenance started background certificate maintenance {"cache": "0xc0005f2e70"}
2021/08/08 13:25:34.731 INFO tls cleaning storage unit {"description": "FileStorage:/root/.local/share/caddy"}
2021/08/08 13:25:34.734 INFO tls finished cleaning storage units
2021/08/08 13:25:34.739 INFO autosaved config (load with --resume flag) {"file": "/root/.config/caddy/autosave.json"}
2021/08/08 13:25:34.740 INFO serving initial configuration
Successfully started Caddy (pid=834968) - Caddy is running in the background
Help with structuring my Caddyfile to achieve the desired outcome would be greatly appreciated <3
