2.3.0
Caddy run
macOS Big Sur
Caddy run
N/a
server {
listen 443 ssl http2;
listen [::]:443 ssl http2;
server_name pixelfed.example; # change this to your fqdn
root /usr/share/webapps/pixelfed/public; # path to repo/public
ssl_certificate /etc/nginx/ssl/server.crt; # generate your own
ssl_certificate_key /etc/nginx/ssl/server.key; # or use letsencrypt
ssl_protocols TLSv1.2;
ssl_ciphers EECDH+AESGCM:EECDH+CHACHA20:EECDH+AES;
ssl_prefer_server_ciphers on;
add_header X-Frame-Options "SAMEORIGIN";
add_header X-XSS-Protection "1; mode=block";
add_header X-Content-Type-Options "nosniff";
index index.html index.htm index.php;
charset utf-8;
client_max_body_size 15M; # or your desired limit
location / {
try_files $uri $uri/ /index.php?$query_string;
location = /favicon.ico { access_log off; log_not_found off; }
location = /robots.txt { access_log off; log_not_found off; }
error_page 404 /index.php;
location ~ \.php$ {
fastcgi_split_path_info ^(.+\.php)(/.+)$;
fastcgi_pass unix:/run/php-fpm/php-fpm.sock; # make sure this is correct
fastcgi_index index.php;
include fastcgi_params;
fastcgi_param SCRIPT_FILENAME $document_root$fastcgi_script_name; # or $request_filename
location ~ /\.(?!well-known).* {
deny all;
server { # Redirect http to https
listen 80;
listen [::]:80;
return 301 https://$host$request_uri;
N/A
I deleted 90% of the nginx file, and converted the only 10% I knew how
I’m really trying to learn. This is probably the most complex one I’ve attempted. Thank for your time!
