Request for comment: path based reverse proxy with redirect and remote_ip check
I have to reverse proxy three services on three different paths on the same host. The services should only be reachable from a certain IP address, which is an internal NAT gateway. Also a path without trailing / should be redirected to the path with trailing /. The services themselves are served upstream from the same path as given in the Caddy config, so handle works here. Here is what I have so far:
service.example.com {
	@internal-gw remote_ip 10.11.12.13/32
	redir /service1 /service1/ 308
	handle /service1/* {
		reverse_proxy @internal-gw http://service1.example.com
	redir /service2 /service2/ 308
	handle /service2/* {
		reverse_proxy @internal-gw http://service2.example.com
	redir /service3 /service3/ 308
	handle /service3/* {
		reverse_proxy @internal-gw http://service3.example.com
This works as expected, with just one little exception: the redir directives don’t check for the @internal-gw, possibly leaking that there is some kind of service due to the redirect, that would be sent regardless of the remote_ip. Accessing the services from other clients doesn’t work due to the reverse_proxy directive with the @internal-gw matcher.
What would be the recommended way to configure this, so that the service names don’t leak? Maybe with a route like given below?
	route @internal-gw {
			reverse_proxy http://service1.example.com
			reverse_proxy http://service2.example.com
			reverse_proxy http://service3.example.com
Or would a different approach be better? I also have to consider, that at some point one of the services should be reachable from any address. With the route approach I would move the redir and handle directive for this service out of the route directive.
One other approach I was thinking of was using a named matcher for the redir directives like below. But this would mean creating a named matcher for each service.
@service3 {
	path /service3
redir @service3 /service3/ 308
Any recommendations and comments are welcome! :slight_smile:
n/a
v2.9.1
Docker in a Nomad cluster
n/a
n/a
n/a
n/a
Yes, the way you specified the `route` directive should work. A redirect will not happen without the required `remote_ip` range or addresses.
I don’t believe using a named matcher with redir wil work at all.
Thank you. I implemented the route variant and it works es expected.
