): 2.4.4
Caddy run
Ubuntu 20.04.3
sudo systemctl reload caddy
email chehinjuan@gmail.com
(static) {
@static {
file
path *.ico *.css *.js *.gif *.jpg *.jpeg *.png *.svg *.woff *.json
header @static Cache-Control max-age=5184000.
(segurity) {
# enable HSTS
# keet referrer data off HTTP connections
Hello, I am trying to run “sudo systemctl reload caddy” but I get the following error. My hrothgar.conf file is
hrothgar.learn-code.ca {
encode zstd gzip
import static
import securityroot * /var/www/hrothgar file_server
output file /var/logs/…
