1. Output of caddy version
Docker - image: caddy:2.6.2-alpine
Latest docker
runs as service
opencart.a.com {
reverse_proxy {
header_up host {http.reverse_proxy.upstream.host}
header_down Location ([^:]+://[^:]+(:[0-9]+)?/) ./
to opencart:80
Php is trying to do redirects with the header function:
header(‘Location: ’ . str_replace(array(’&‘, “\n”, “\r”), array(’&', ‘’, ‘’), $url), true, $status);
But, an error message is displayed instead:
Cannot modify header information - headers already sent by
* Trying 2.2.2.2:443...
* TCP_NODELAY set
* Connected to opencart.a.com (2.2.2.2) port 443 (#0)
* ALPN, offering h2
* ALPN, offering http/1.1
CApath: /etc/ssl/certs
* subject: CN=opencart.a.com
* start date: Nov 14 03:38:53 2022 GMT
* expire date: Feb 12 03:38:52 2023 GMT
* subjectAltName: host "opencart.a.com" matched cert's "opencart.a.com"
* issuer: C=US; O=Let's Encrypt; CN=R3
* SSL certificate verify ok.
* Using Stream ID: 1 (easy handle 0x55707aa5f8c0)
> GET / HTTP/2
> Host: opencart.a.com
> user-agent: curl/7.68.0
> accept: */*
< HTTP/2 200
< content-type: text/html; charset=UTF-8
< date: Fri, 18 Nov 2022 07:02:06 GMT
< server: Caddy
< server: Apache/2.4.38 (Debian)
< set-cookie: OCSESSID=e3ff75e60419075e488471398a; path=/
< set-cookie: OCSESSID=a3fda52523ea41f8f036d71acc; path=/
< set-cookie: language=en-gb; expires=Sun, 18-Dec-2022 07:02:06 GMT; Max-Age=2592000; path=/; domain=opencart
< set-cookie: currency=USD; expires=Sun, 18-Dec-2022 07:02:06 GMT; Max-Age=2592000; path=/; domain=opencart
< vary: Accept-Encoding
< x-powered-by: PHP/7.2.34
* Connection #0 to host opencart.a.com left intact
<b>Notice</b>: Undefined index: route in <b>/var/www/html/vqmod/vqcache/vq2-catalog_controller_common_header.php</b> on line <b>17</b><b>Notice</b>: Undefined index: route in <b>/var/www/html/vqmod/vqcache/vq2-catalog_controller_common_header.php</b> on line <b>17</b><b>Notice</b>: Undefined index: route in <b>/var/www/html/vqmod/vqcache/vq2-catalog_controller_common_header.php</b> on line <b>17</b><b>Notice</b>: Undefined index: route in <b>/var/www/html/vqmod/vqcache/vq2-catalog_controller_common_header.php</b> on line <b>17</b><b>Notice</b>: Undefined index: route in <b>/var/www/html/vqmod/vqcache/vq2-catalog_controller_common_header.php</b> on line <b>17</b><b>Warning</b>: Cannot modify header information - headers already sent by (output started at /var/www/html/catalog/controller/startup/error.php:34) in <b>/var/www/html/system/library/response.php</b> on line <b>36</b>
tried copy_response and copy_response_headers, but I haven’t seen a clear example of the match variables, so I haven’t been get those to work successfuly
