from is the request path to match (it must match exactly, except for /, which is a catch-all).
I assumed this means any path ending with /, but, no, it looks like root is special-cased. I’m trying to set up a stub site that just redirects to somewhere else with a fixed-up path. I thought I could use a rewrite combined with a redir to get what I wanted, but with redir so restricted it seems impossible…
Ah i didn’t think about doing that. So in this case the /foo/xyz is caught by :8080/foo and redirects to /bar/xyz (because inside :8080/foo the root is at /foo/ not / so {uri} is /xyz), which is then caught by :8080. Is that correct?
It does avoid regex, but wouldn’t it cause a second request & round trip from the client? That seems more expensive than a regex to me. I guess it 301’s by default, so if the same client will request the same resource multiple times it might be worth it since the redirect will be aggressively cached.
In my case I ended up having a couple paths that needed more fixing up than just altering the top directory, and I expect many more new clients than repeat clients obviating the caching argument, so regex is probably my best bet.
Close. The {uri} is still actually /foo/xyz so it redirects to /bar/foo/xyz, but it is then indeed caught by the :8080 block.
It does, but as you say, it should be cached by the client - and you’re already doing one anyway:
So all we’re doing is cutting out the added regex.
If you want to serve different content without causing a second request, you want to rewrite and then not redirect at all. You can do that without a regex too, no site block required either:
# example.com/foo/xyz -> example.com/bar/foo/xyz
rewrite /foo {
to /bar{uri}
