1. Output of caddy version
: 2.6.2
Docker container using this command to run the container: docker run -d --name caddy -p 80:80 my-caddy. I’ve built the image from the caddy image using my caddyfile. All it has in the caddy file is: overseerr.domain.net {
reverse_proxy 172.17.0.6:5055
windows 11. Docker desktop latest versionb. Command:
Paste command here.
Dockerfile contains this: FROM caddy
COPY caddyfile /etc/caddy/Caddyfile
I run this to build the image: docker build -t my-caddy . Then I run this to run the container: docker run -d --name caddy -p 80:80 my-caddy
d. My complete Caddy config: i haven’t changed anything in the config file so it would be all the defaults. I can still post it though if needed.
I’m trying to reverse proxy Overseerr to Overseerr.domain.net. So if I browse Overseerr.domain.net it brings up the app. I’ve added my external ip address of my computer to the dns record of my domain. I can go to Overseerr.domain.net but it pulls up my modem login screen. Not the Overseerr app. I’m not sure what step I’m missing in all of this.
Not even sure what logs I would really need at this point. I think it’s more of a configuration issue.
I’ve seen other post on the forum with sonarr and radarr and have tried different combinations of a caddy file and docker commands like this docker run -d --name caddy -p 80:80 --link overseerr:localhost my-caddy. I’ve also tried putting the container name which is Overseerr in the caddyfile instead of the up address but that didn’t help either.
