I’ve built a docker container that runs both Caddy and a nodejs server. Caddy handles static assets and then hands off other requests to a node server running in the same docker container. My Caddyfile is here:
:2015
root /srv/build/
# send other requests to backend
proxy / localhost:81 {
except /static favicon.ico favicon.png index.html asset-manifest.json
startup node server &
This seems to work fine, but I was wondering why I need the &
at the end of my startup directive. It makes sense that I would need it, otherwise the node server runs in the foreground and caddy cannot continue processing. However, when comparing this with abiosoft/caddy:php
, php-fpm
is started in that container without the trailing &
. Is this because php-fpm
is not the actual daemon and just starts the process in the background and then exits or something?
Here is a link to the Caddyfile for abiosoft/caddy:php
: caddy-docker/Caddyfile at master · abiosoft/caddy-docker · GitHub
and the source:
0.0.0.0
browse
fastcgi / 127.0.0.1:9000 php
startup php-fpm7
log stdout
errors stdout
