I have a fairly generic set of header and subheader directives applied to a majority of my domains/subdomains. Right now, I’m storing them in a snippet along with my custom Porkbun DNS TLS directive:
(headers) {
header Content-Security-Policy "upgrade-insecure-requests"
(subheaders) {
header_up X-Real-IP {remote}
header_down Strict-Transport-Security max-age=31536000
(porkbun) {
dns porkbun {
api_key {env.PORKBUN_API_KEY}
api_secret_key {env.PORKBUN_API_SECRET_KEY}
This is how most of the subdomains look as a result:
sftp.mydomain.com {
import headers
import porkbun
reverse_proxy sftpgo:8080 {
import subheaders
Is there any way to format the subheader snippet so that I can add it to the same location as ‘headers’ and ‘porkbun’ so I don’t have to create so many additional lines in my Caddyfile and keep it easy to read at a glance?
For example:
sftp.mydomain.com {
import headers
import porkbun
import subheaders
Or is there altogether a better way I should be approaching this?
N/A
Latest
docker compose
N/A
N/A
N/A
