Hi there,
I am trying to pass though three backends used for kubernetes admin for kubectl. These are just SSL backends with self assigned certs (on the backend) which you must use to connect. If I can just get pass though working so it does nothing, it should work fine.
I have gone though the docs and also google but cant seem to find away but I highly suspect it sould be possibe with caddy but am coming up short.
I have tried various ways to pass it though without sucess because the external cert is stepping in and breaking auth. I have also tried switching off tls but then wont respond at all. Below is my latest attempt.
import ../headers.inc
import ../common.inc
dns cloudflare
wildcard
# ------ Kubernetes ------
# Backend (k8s)
proxy / https://node01-k8s.example.work:6443, https://node02-k8s.example.work:6443, https://node03-k8s.example.work:6443 {
policy first
health_check /healthz
insecure_skip_verify
websocket
Does anyone have an idea or clue how this can be done? any tips/suggestions would be really greatful.
Kind Regards,
Majestic
