v2.5.0 h1:eRHzZ4l3X6Ag3kUt8nj5IxATprhqKq/wToP7OHlXWA0=
I am trying to use the cache module GitHub - caddyserver/cache-handler: Distributed HTTP caching module for Caddy to set & invalidate pages in the cache.
I can see the cache is working correctly on my responses:
GET /api/platform/test/cache
Cache-Control: max-age=200, public
Cache-Status: Souin; hit; ttl=192
Surrogate-Key: bla
Also on refresh I can see the request does not hit my upstream in the caddy logs and returns directly.
When I now visit the configured souin api I can see that the request is indeed listed:
"GET-localhost-/api/platform/test/cache",
"GET-localhost-/favicon.ico{-VARY-}Accept-Encoding:gzip, deflate, br",
"STALE_GET-localhost-/api/platform/test/cache",
"STALE_GET-localhost-/favicon.ico{-VARY-}Accept-Encoding:gzip, deflate, br"
My first question is: What happened to the surrogate-key I set? I was expecting to see a key:value list?
My second question is: How do I purge only one item on the displayed list? When I fire a PURGE
request to the souin api with Surrogate-key header it purges the full cache instead of just the one item?
Anyone able to give me a pointer I think im stuck on a small thing.
"apps" => [
"cache" => [
'api' => [
'basepath' => '/__cache',
'souin' => [
'basepath' => '/souin',
'enable' => true,
"log_level" => "DEBUG",
'ttl' => '3600s',
When sending a PURGE
request with the specified Surrogate-Key: bla
header it seems to DropPrefix
for [ ]
instead of just my key?
caddy_1 | badger 2022/05/15 05:52:53 INFO: DropPrefix called for []
caddy_1 | badger 2022/05/15 05:52:53 INFO: Writes flushed. Stopping compactions now...
caddy_1 | badger 2022/05/15 05:52:53 INFO: DropPrefix done
caddy_1 | badger 2022/05/15 05:52:53 INFO: Resuming writes
