2.4.5
Installed via official Ansible role
Ubuntu 20.04 LTS.
/usr/local/bin/caddy" run --environ --config "/home/fuzzy/caddy/Caddyfile
; Ansible managed
; source: https://github.com/mholt/caddy/blob/master/dist/init/linux-systemd/caddy.service
; version: 6be0386
; changes: Set variables via Ansible
After=network-online.target
Restart=on-failure
StartLimitInterval=86400
StartLimitBurst=5
User=www-data
Group=www-data
ExecStart="/usr/local/bin/caddy" run --environ --config "/home/fuzzy/caddy/Caddyfile"
ExecReload="/usr/local/bin/caddy" reload --config "/home/fuzzy/caddy/Caddyfile"
; Use a minimal /dev
PrivateDevices=true
ProtectHome=false
; ^` except /etc/ssl/caddy, because we want Letsencrypt-certificates there.
; This merely retains r/w access rights, it does not add any new. Must still be writable on the host!
ReadWriteDirectories=/etc/ssl/caddy /var/log/caddy
; They further retrict privileges that can be gained by caddy.
NoNewPrivileges=true
Links provided below if needed
I run Caddy in two places, on my VPS which is public facing and then on a local server that has a wireguard connection to the VPS. What I’d like to do is be able to set up my Adguard/DNS on my home network to point to the local server so I avoid putting traffic through the VPS (and also eliminate as much latency as possible). Currently I have a setup that’s working but it terminates TLS on the VPS and forwards the traffic to the local Caddy server over http. I’d like to also have HTTPS when i’m on my home network.
What I’d ideally like to do is have only reverse_proxy
entry per domain. IE just something like this:
photos.example.com {
tls PATH_TO_CERTS
reverse_proxy http://192.168.1.20:8000
import headers
That could handle both the connection from the VPS and internally (and give me HTTPS in both spots). I figured out a solution using request matching with something like this:
https://photos.example.com {
@local remote_ip 192.168.0.0/16 172.16.0.0/12 10.0.0.0/8
reverse_proxy @local http://192.168.1.20:8000
tls PATH_TO_CERTS
import headers
http://photos.example.com {
import headers
But that’s kludgey on a large scale. Is there a way to streamline this to be a single block per subdomain? Or alternatively, is it possible to do HTTPS on both the VPS and local server so it wouldn’t matter? I tried something like this on the VPS/local server to do HTTPS/HTTPS but all I got was a blank page:
VPS:
*.example.com {
tls PATH_TO_CERTS
@photos host photos.example.com
handle @photos {
reverse_proxy https://10.10.10.10:443
import personal_headers
import no_robots
Local server:
tls PATH_TO_CERTS
import headers
If you really want to see my full Caddyfiles of my existing setup (that’s HTTPS->HTTP), here’s the VPS one and the local server one
No errors that I can see
See above
