HI folks, currently im using Caddy as a reverse proxy. What would it be called or what direction should I be looking if I next want to send a certain domain to an external IP rather than connecting to one in the LAN ?
I know so far that I get an SSL error when trying to do it with the same syntax as a regular reverse proxy entry
Please fill out the help topic template you’re presented with when opening a new topic. We need the information requested in the template to help you.
