v2.5.0-beta.1 h1:lF5wWqqDJ6HjETbnBILvTAeKcThsz1+OeWB+d1tWxp4=
With the systemd service
Debian 11 – systemd 247
sudo systemctl start caddy.service
# /etc/systemd/system/caddy.service
# caddy.service
# for your installation.
Type=notify
servers :443 {
protocol {
experimental_http3
rss.eban.eu.org {
Access-Control-Allow-Origin *
Access-Control-Allow-Credentials true
Access-Control-Allow-Methods *
Access-Control-Allow-Headers *
defer
rewrite /liberation /arc/outboundfeeds/rss/?outputType=xml
reverse_proxy /arc/outboundfeeds/rss/?outputType=xml {
header_down -Access-Control-Allow-Origin
dynamic a www.liberation.fr 9000
output stderr
level info
I’d like caddy to do the following thing :
user makes GET to https://rss.eban.eu.org/liberation
caddy receives this request, make a GET to <![CDATA[Libération]]>, strips the CORS header to add back a wildcard CORS and send it back to the user
Please see d.
, but this doesn’t work
