POST /photos
GET /photos/photo_id
DELETE /photos/photo_id
In the GET case, I want Candy to serve the photos from disk.
In the POST and DELETE cases, I want it to proxy the requests to my Node.js upstream servers.
As far as I can tell, neither the proxy directive nor except support specifying HTTP methods.
The most trivial (and slightly ugly) solution would be having a separate path, e.g. /p/photo_id, for GET requests, with /p passed to except. However it just does not feel “idiomatic”. Since this seems a common use case, how would you guys approach this issue?
Someone correct me if I’m wrong but this is not really done in webserver configuration, usually.
Neither Apache nor nginx can conditionally proxy based on request method. Both have capable workarounds involving rewrites. Caddy might be capable of similar.
How would I approach this issue? The application I’m proxying to would handle POST, DELETE, and GET requests, ideally. Outside of this, I might consider writing an intermediary program to handle routing between the Node.js uploader and the disk based file server (this would be pretty easy in Go, I believe).
That is correct. HTTP VERBS are usually handled with very complicated Rewrite rules, or directly in the application API. I would suggest that it’s best handled in the API.
So /photos/image1.jpg is that what you’re suggesting? Of course Caddy can do that, that’s just a read action.
So the real issue is your dynamic paths, POST an upload action, and DELETE a file delete action. I highly suggest these go behind a different URL path. Either /api/photos/ or /photos/api. Whichever you choose, your Node app is going to need to handle file logic. Image processing, writing file to disk, filename collisions, permissions (who can upload), etc.
Also how are you going to know what’s on disk? Your API should provide some query mechanism that points to the “static” URL, or just straight serves up the file. That is all outside of Caddy.
Caddy can serve static files all day long. But it’s not going be able to do any of those dynamic functions unless you write your own plugin.
So in the absence of a capable workaround, an intermediary program would be like a custom plugin, which intercepts the requests before the proxy plugin has a chance to act upon it, and if the request matches verb + path combo, Caddy returns the photo from the disk, otherwise passing control to the next middleware (or plugin, not sure about the correct term). Right?
Since started using Caddy only yesterday, I am not sure how easily could this be done, however it seems to be one possible solution to this problem.
Yes, that is what I am trying to achieve.
Basically this is the workaround I am using for the time being. In the current form: /photos/image1.jpg for GET actions. I have except /photos inside the proxy directive, therefore Caddy reads the photos from disk. I have a /p endpoint on the Node.js side for everything else photo related, like delete photo, create photo, but NOT get photo. Caddy proxies all those requests to my Node.js server. But this is the exact situation I like to avoid.
As far as I see it, conceptually /photos/image1.jpg is one single resource, I don’t really like the idea of splitting it up because of purely technical limitations.
I have omitted from my original question, but I have a distributed “image processing pipeline” , which makes sure whatever photo someone uploads via the Node.js endpoint, it will eventually become available inside Caddy’s working directory. That is why I want Caddy to do a file read only in the case of a GET method.
Also, I am trying to use the same single Caddy instance as a static file server and as a reverse proxy, at least for the start. Later on I might rewrite the /photos endpoint as a Candy plugin, and have separate static file servers, which solves this current issue, but at the moment I see it as a premature optimisation.
Looking at Apache and nginx, they don’t appear to have any mechanism to do proxy differently based on HTTP method. At least nothing simple What they do have is some frankly arcane and hard to administer Rewrite rules, where you might be able to do something similar to what you want.
So that’s Apache and nginx.
What makes Caddy powerful is it’s also simple, and extendable. If you really don’t want the Node backend to serve the file, and want something simple, use a different path. I know that doesn’t match the REST ideals, but that’s the quick solution.
Otherwise, you could hack on the proxy code, directly. Quickly looking, I’d start with the match function, and modify it to look at the http.Request which contains the Method field. Then you could match proxy upstream on that condition as well. It also means you would have to extend the proxy directive to add HTTP methods
But that still leaves GET which wouldn’t be proxied…so that requires more hacking somewhere
See where this going?? I would just use a custom path, or just serve it all from Node process(s). Come to think of it that’s another option, fire up multiple Node processes, and just use Caddy a front-end load-balancer. Sorry if that doesn’t help
But again the ideal solution would definitely be for the same endpoint to handle all the verbs (i.e. for the Node.js server to handle serving files back to Caddy to be returned to the client).
Some great comments from @jim regarding extending Caddy for this purpose, though.
I think I am going to stick to using the two-path workaround as was suggested by @jim, at least for the time being. And if time permits, probably moving towards a single-endpoint solution. I also like the idea of running a simple custom-made file serving process, instead of using a full-blown server.
I am a bit reluctant to use Node as a static file server, though, because in the past I saw numerous benchmarks showing that Node.js is not the best option for that use case. However in those benchmarks it was compared against Nginx. (After some googling, I found that, in terms of static file sharing, the golang-based solutions are comparable to the Node.js ones, but they are booth outperformed by Nginx.)
For plain static file serving, Go’s net/http package is comparably fast to nginx because they both use unix sendfile. You’ll find that Caddy is quite fast at serving static files, do not worry. (Although we have a lot of optimization work to do!)
[quote=“Whitestrake, post:7, topic:1689”]
[/quote]Thanks @Whitestrake, it would certainly be a unique feature to be able to proxy based on HTTP method. Maybe something to look into at some point, and it would certainly be unique amongst HTTP servers I believe.
