hi,
I try to access the backend servers via proxy.
I start three caddy servers as follow :
- server0 : localhost:2000
- server1 : localhost:2001
- server2 : localhost:2002
The server0’s Caddyfile is :
localhost:2000 {
tls off
errors visible
proxy /blog localhost:2002
proxy / localhost:2001
gzip
log ./access.log
when access http://localhost:2000 via chrome, it’s correct.
but access http://localhost:2000/blog, it returns “404 Not Found”
I tried this on both caddy 0.9 and 0.9.1, it plays in the same way.
Is there anything wrong with the config?
thanks for your help in advance.
1lann
(Jason Chu)
#2
What happens if you try to access http://localhost:2002 in your web browser?
both work fine when i access the website via localhost:2001 or localhost:2002.
In fact, when i access via proxy,
only proxy / the-site-url
works,
all other proxy /xxx the-site-url
FAILED.
1lann
(Jason Chu)
#4
Perhaps you meant to use the without
option for proxy.
Try
proxy /blog localhost:2002 {
without /blog
This may break other resources on the page however, if they are not referenced relative to the page.
I have tried this, always returns 404,
abiosoft
(Abiola Ibrahim)
#7
Can you verify access log in the other servers and see if the requests are proxied to them. It may be the proxy returning 404, not server0.
thanks for your concern. @abiosoft
the access log tells that it is the server2(port 2002) who return the 404.
here is the access log :
- server0 (port 2000) :
::1 - [25/Aug/2016:11:50:16 +0800] "GET /blog HTTP/1.1" 404 38
- server2 (port 2002) :
abiosoft
(Abiola Ibrahim)
#9
Can you share server2’s Caddyfile ?
sure, here it is :
localhost:2002 {
tls off
errors visible
root /Users/HANK/www/blog/public
gzip
log ./access-blog.log
abiosoft
(Abiola Ibrahim)
#11
So, what do you expect it to respond with ?
Looks like this is what you need.
without /blog
What paths in server2 are valid ?
yes, it works!
I misunderstand the without parameter.
thank you very much, @abiosoft
sorry for my misunderstand the without parameter. your answer is right, thank you!
system
(system)
closed
#14
