I am trying to setup Caddy as reverse proxy to pass requests to another physical server running caddy as well on the same LAN.
Here is my setup:
I have 2 servers behind a router.
Server A is 192.168.0.2
Server B is 192.168.0.3
My ISP gives me a fixed IP, I have a domain name, and I forward all requests on the port 443 (I want https only) to the server A.
The caddyfile of the server A looks like this and it works correctly:
subdomain1.domain.com {
root /srv/http/subdomain1
dns gandiv5
And the caddyfile of the server B looks like this:
subdomain2.domain.com {
root /srv/http/subdomain2
dns gandiv5
It does not work, I have a time-out when I try to reach subdomain2.domain.com from the WAN.
Also I am not sure if the DNS challenge must be solved by the proxy (server A) or by the server hosting the app (server B)
The DNS record has been tested without proxy setup and it works.
The 2 other points are network related and I guess this is where something is wrong.
If my knowledge is correct, I don’t need any additional forwarding rule beside the existing one (public IP:443 to 192.168.0.2:443) as I stay on the same LAN when the packets are forwarded from 192.168.0.2 to 192.168.0.3 but maybe I am wrong.
The firewall is embedded in the router and I assume it filters the packets coming from the WAN not LAN to LAN. Also none of the servers have a FW.
