Provide metrics on a different port
I have a reverse_proxy serving on port :443 and the domain is pointing A record to the server, which is working fine as https://caddy.example.com.
In order to measure the metrics, I want to access the metrics on a different port like
http://xx.xx.xx.xx:2020/metrics
Please note, that I do not want to use the domain name here and use directly the IP address of the instance.
Error: automation policy from site block is also default/catch-all policy because of key without hostname, and the two are in conflict: []certmagic.Issuer(nil) != []certmagic.Issuer{(*caddytls.ACMEIssuer)(0x40002aee00), (*caddytls.ZeroSSLIssuer)(0x400047fa40)}
a. System environment: Ubuntu 22.04 (Linux)
caddy adapt
caddy reload
        email anuj.sharma@example.io
        on_demand_tls {
                ask https://webhook.site/69c70c2e-818d-4c9d-940e-43daaed3c0c9
        servers {
                metrics
:2020 {
                metrics
:443 {
        reverse_proxy {
                to my-app-load-balancer-207asdf23690.us-west-2.elb.amazonaws.com
        tls anuj.sharma@example.io {
                on_demand
                # Response Headers
                set X-Content-Type-Options nosniff
                set X-Frame-Options DENY
                set X-XSS-Protection "1; mode=block"
                set Referrer-Policy no-referrer-when-downgrade
Strange. I’d expect that config to work as-is :frowning:
You can fix it by changing it to http://:2020 and it won’t attempt to set up an automation policy.
set is not a thing. Please review the docs. This will be using the header value replacement syntax, trying to change a header called Set, which is not your intent.
It’s so hard… willing to revisit this but that code is super duper complicated.
Found an alternative fix; remove the email from the tls directive in your :443 block, because it’s redundant since you already defined the email global option. Or use a different email address.
The reason why it actually fixes the error is really in-depth and tricky and probably not something we care to solve, frankly, because it’s very much an edge-case.
@matt if you’re feeling adventurous… the gist is that the :2020 block sets catchAllAP = ap because if len(sblockHosts) == 0 && catchAllAP == nil passes since it’s first… I think we should avoid that line if the port is not the https_port and there are no hosts.
