Caddy V2
Running on Windows Server 2016
email user@abc.com
ssrs.abc.com {
tls email {
dns cloudflare API Key
output file c:\caddy\logs\ssrs_access.log {
roll true # Rotate logs, enabled by default
roll_size_mb 10 # Set max size X MB
roll_gzip true # Whether to compress rolled files
roll_local_time true # Use localhost time
roll_keep 3 # Keep at most X log files
roll_keep_days 7 # Keep log files for X days
route /auth* {
authp {
backends {
azure_saml_backend {
method saml
realm azure
provider azure
idp_metadata_location c:\caddy\certs\ssrs.xml
idp_sign_cert_location c:\caddy\certs\ssrs.cer
tenant_id "Tenant ID"
application_id "App ID"
application_name "SSRS"
entity_id "urn:caddy:ssrs"
acs_url https://reports.abc.com/auth/saml/azure
ui {
links {
"Reports Viewer" /reports
route /reports* {
jwt {
primary yes
set auth url /auth
allow roles SSRS_Management SSRS_Sales
reverse_proxy http://localhost:8080
route {
redir https://{hostport}/auth 302
The SAML auth and revers proxy into SSRS is working just fine. The issue I’m having is figuring out how to pass the user/groups from my SAML login into SSRS so the user is not having to login with SAML and then type in windows auth in order to login.
Anyone have any idea on how I would accomplish this?
I’m also receiving this in my logs
2021/10/06 22:40:02.804 ERROR http.handlers.authentication auth provider returned error {“provider”: “jwt”, “error”: “no token found”}
