1. My Caddy version (caddy -version
I installed with this script wget -N --no-check-certificate https://raw.githubusercontent.com/ToyoDAdoubiBackup/doubi/master/caddy_install.sh && chmod +x caddy_install.sh && bash caddy_install.sh
caddy -version
didn’t work for me.
Ubuntu18.04
/etc/init.d/caddy start
d. My complete Caddyfile:
gzip
tls myemailhere@email.com
proxy / 127.0.0.1:8080 {
header_upstream Host {host}
header_upstream X-Forwarded-For {remote}
rsshub.mydomainhere.com {
gzip
proxy / 127.0.0.1:1200 {
search.mydomainhere.com {
gzip
proxy / 127.0.0.1:8888 {
I want to move my services from one VPS to another one. So I added my old domain to the new VPS and changed the NS to make the domain is pointing to my new VPS. Then I installed caddy with the script above. I copied the Caddyfile from the old VPS to the new VPS. Then I start caddy as usual /etc/init.d/caddy start
. When I check the log it tells me failed to obtain certificate
failed to obtain certificate: acme: error: 429 :: POST :: https://acme-v02.api.letsencrypt.org/acme/new-order :: urn:ietf:params:acme:error:rateLimited :: Error creating new order :: too many failed authorizations recently: see https://letsencrypt.org/docs/rate-limits/, url:
Then I copied both Caddyfile and caddy to my new VPS, then run caddy. It still doesn’t work. So I guess right now I have to wait for another week before I try anything else.
My question is that what is the proper way to move the certificate from one VPS to another VPS. I want to use the same domain on my new VPS. Thanks
