v2.4.1 h1:kAJ0JB5Xk5gPdTH/27S5cyoMGqD5lBAe9yZ8zTjVJa0=
Windows 10 Pro with go version go1.16.3 windows/amd64
I am running caddy from within a library of a dns provider I am developing using
xcaddy run
Windows 10 Pro, Powershell
xcaddy run
Not used
test.kmpm.io
issuer acme {
email "<redacted email>"
timeout "15m0s"
propagation_timeout "15m0s"
dns loopia {
username "<redacted>"
password "<redacted>"
resolvers ns1.loopia.se
respond "Hello, world!"
I am developing a acme dns provider for caddy for https://loopia.se
Loopia have a really long propagation time for DNS changes, up to 15 minutes and I cant get caddy/acme to wait long enough.
When using JSON config you could set propagation_timeout
that seems to fix it but I can’t figure out how to set it using a Caddyfile.
Could it be as simple as caddyfile not supporting the propagation_timeout directive? I really hope not since there is a lot of extra fluff if I were forced to use JSON because of one single line.
xcaddy run
2021/05/25 17:57:31 [INFO] Resolved relative replacement github.com/kmpm/libdns-loopia=>../libdns-loopia to D:\Code\kmpm\dns-loopia\libdns-loopia
2021/05/25 17:57:31 [INFO] Temporary folder: C:\Users\peter\AppData\Local\Temp\buildenv_2021-05-25-1757.944082367
2021/05/25 17:57:31 [INFO] Writing main module: C:\Users\peter\AppData\Local\Temp\buildenv_2021-05-25-1757.944082367\main.go
2021/05/25 17:57:31 [INFO] Initializing Go module
2021/05/25 17:57:31 [INFO] exec (timeout=10s): C:\Program Files\Go\bin\go.exe mod init caddy
go: creating new go.mod: module caddy
go: to add module requirements and sums:
go mod tidy
2021/05/25 17:57:31 [INFO] Replace github.com/kmpm/caddy-dns-loopia => D:\Code\kmpm\dns-loopia\caddy-dns-loopia
2021/05/25 17:57:31 [INFO] exec (timeout=10s): C:\Program Files\Go\bin\go.exe mod edit -replace github.com/kmpm/caddy-dns-loopia=D:\Code\kmpm\dns-loopia\caddy-dns-loopia
2021/05/25 17:57:31 [INFO] Replace github.com/kmpm/libdns-loopia => D:\Code\kmpm\dns-loopia\libdns-loopia
2021/05/25 17:57:32 [INFO] exec (timeout=10s): C:\Program Files\Go\bin\go.exe mod edit -replace github.com/kmpm/libdns-loopia=D:\Code\kmpm\dns-loopia\libdns-loopia
2021/05/25 17:57:32 [INFO] Pinning versions
2021/05/25 17:57:32 [INFO] exec (timeout=0s): C:\Program Files\Go\bin\go.exe get -d -v github.com/caddyserver/caddy/v2
go get: added github.com/caddyserver/caddy/v2 v2.4.1
2021/05/25 17:57:34 [INFO] Build environment ready
2021/05/25 17:57:34 [INFO] Building Caddy
2021/05/25 17:57:34 [INFO] exec (timeout=0s): C:\Program Files\Go\bin\go.exe mod tidy
go: found github.com/kmpm/caddy-dns-loopia in github.com/kmpm/caddy-dns-loopia v0.0.0-00010101000000-000000000000
2021/05/25 17:57:34 [INFO] exec (timeout=0s): C:\Program Files\Go\bin\go.exe build -o D:\Code\kmpm\dns-loopia\caddy-dns-loopia\caddy.exe -ldflags -w -s -trimpath
2021/05/25 17:57:39 [INFO] Build complete: caddy.exe
2021/05/25 17:57:39 [INFO] Cleaning up temporary folder: C:\Users\peter\AppData\Local\Temp\buildenv_2021-05-25-1757.944082367
2021/05/25 17:57:39 [INFO] Running [caddy.exe run]
2021/05/25 15:57:40.143 INFO using adjacent Caddyfile
run: adapting config using caddyfile: parsing caddyfile tokens for 'tls': Caddyfile:10 - Error during parsing: unrecognized ACME issuer property: propagation_timeout
2021/05/25 17:57:40 [ERROR] exit status 1
- tried moving around the
propagation_timeout
to all kind of places in the caddyfile - tried with the
timeout
as a replacement - got it working using JSON config with
propagation_timeout
, but it’s a awful amount of extra config just to add that single directive
