My main issue is that I am a newbie so I got stuck while implementing. Right now I have this:
The form is served via Caddy (root directory)
I have a Go process running on port 3000 that should handle the data. I have tested this handler with a /template index.html form and works fine. How do I tell the Caddy server that the POST will be handled by the process running on port 3000?
Hi @ETua, welcome to the Caddy community.
It sounds like you want to proxy a request from Caddy to your Go process, but only for POST requests.
The proxy
directive can’t distinguish between methods by itself, but you can use the rewrite
directive with an if
statement to check the method via placeholder. It might look like this:
example.com {
# Prepend with "/post" so the proxy knows which requests to forward on
rewrite /endpoint {
if {method} is POST
to /post{uri}
# Proxy anything starting with "/post", but strip out the prefix first
proxy /post localhost:3000 {
without /post
# transparent might be useful if your app needs info on the actual client
Changing /post
and /endpoint
to suit your requirements, of course.
https://caddyserver.com/docs/rewrite
https://caddyserver.com/docs/proxy
https://caddyserver.com/docs/placeholders
