NAME=“Ubuntu”
VERSION=“20.04.3 LTS (Focal Fossa)”
ID=ubuntu
ID_LIKE=debian
PRETTY_NAME=“Ubuntu 20.04.3 LTS”
VERSION_ID=“20.04”
(proxy_upstream) {
# Enable access logging to STDOUT
log
reverse_proxy https://BACKEND.com {
header_up X-Forwarded-Host {host}}
#tls_insecure_skip_verify
compression off
https://FRONEND.com {
tls internal {
client_auth {
mode require
trusted_leaf_cert_file /path/to/client.pem
import proxy_upstream
I’m trying to use client authentication for my Caddy, if auth is OK the request is sent to backend. The request to backend should not include client authentication, this is only between client and Caddy reverse-proxy.
I would like to only allow a single client certificate.
Never see the inbound request im my stdout log.
