2.1.1
Ubuntu 18.04.2 LTS
I use systemd.
# caddy.service
# for your installation.
After=network.target
User=caddy2
Group=caddy2
ExecStart=/usr/local/bin/caddy run --environ --config /etc/caddy2/Caddyfile
ExecReload=/usr/local/bin/caddy reload --config /etc/caddy2/Caddyfile
git.bec-systems.com {
rewrite /explore /
reverse_proxy localhost:3000
With Caddy1, I could use the following Caddyfile to redirect /explore to /. With the above config in Caddy2, I can’t get this to work.
Caddyfile for caddy1 (works):
proxy / localhost:3000
rewrite /explore /
Jul 10 19:07:27 git3 caddy[13018]: {"level":"error","ts":1594408047.454012,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"context canceled"}
I get this message every time I load a page.
I tried removing the rewrite line, and does not seem to make any difference with the above error.
