2.4.6 with dns route53 plugin
Docker
using in docker-compose context, default entry point
"apps": {
"tls": {
"certificates": {
"automate": [
"skynetfree.net", "*.skynetfree.net", "*.hns.skynetfree.net",
"eu-lv-101.skynetfree.net", "*.eu-lv-101.skynetfree.net", "*.hns.eu-lv-101.skynetfree.net"
"automation": {
"policies": [
"issuers": [
"module": "acme",
"email": "devs@siasky.net",
"challenges": {
"dns": {
"provider": {
"name": "route53"
"ttl": "30m"
I am using caddy only to fetch and manage ssl certificates. Most of the time when I’m fetching new certificates, caddy seems to fail somehow - it creates acme records in route53 correctly but then it fails and it fails to clean up those records and then every time it restarts the process it says the records are already there and cannot do anything.
Attaching to caddy
caddy | {"level":"info","ts":1646175973.865099,"msg":"using provided configuration","config_file":"/etc/caddy/caddy.json","config_adapter":""}
caddy | {"level":"info","ts":1646175973.866614,"logger":"admin","msg":"admin endpoint started","address":"tcp/localhost:2019","enforce_origin":false,"origins":["localhost:2019","[::1]:2019","127.0.0.1:2019"]}
caddy | {"level":"info","ts":1646175973.8668988,"logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0xc000904fc0"}
caddy | {"level":"info","ts":1646175973.8679416,"msg":"autosaved config (load with --resume flag)","file":"/config/caddy/autosave.json"}
caddy | {"level":"info","ts":1646175973.8679512,"msg":"serving initial configuration"}
caddy | {"level":"info","ts":1646175973.8679683,"logger":"tls","msg":"cleaning storage unit","description":"FileStorage:/data/caddy"}
caddy | {"level":"info","ts":1646175973.8685193,"logger":"tls","msg":"finished cleaning storage units"}
caddy | {"level":"info","ts":1646175973.86868,"logger":"tls.obtain","msg":"acquiring lock","identifier":"skynetfree.net"}
caddy | {"level":"info","ts":1646175973.8693416,"logger":"tls.obtain","msg":"lock acquired","identifier":"skynetfree.net"}
caddy | {"level":"info","ts":1646175973.8695743,"logger":"tls.obtain","msg":"acquiring lock","identifier":"*.skynetfree.net"}
caddy | {"level":"info","ts":1646175973.8697376,"logger":"tls.issuance.acme","msg":"waiting on internal rate limiter","identifiers":["skynetfree.net"],"ca":"https://acme-v02.api.letsencrypt.org/directory","account":"devs@siasky.net"}
caddy | {"level":"info","ts":1646175973.8697467,"logger":"tls.issuance.acme","msg":"done waiting on internal rate limiter","identifiers":["skynetfree.net"],"ca":"https://acme-v02.api.letsencrypt.org/directory","account":"devs@siasky.net"}
caddy | {"level":"info","ts":1646175973.8700404,"logger":"tls.obtain","msg":"acquiring lock","identifier":"*.hns.skynetfree.net"}
caddy | {"level":"info","ts":1646175973.8702877,"logger":"tls.obtain","msg":"lock acquired","identifier":"*.skynetfree.net"}
caddy | {"level":"info","ts":1646175973.8706462,"logger":"tls.obtain","msg":"lock acquired","identifier":"*.hns.skynetfree.net"}
caddy | {"level":"info","ts":1646175973.870674,"logger":"tls.issuance.acme","msg":"waiting on internal rate limiter","identifiers":["*.skynetfree.net"],"ca":"https://acme-v02.api.letsencrypt.org/directory","account":"devs@siasky.net"}
caddy | {"level":"info","ts":1646175973.8706818,"logger":"tls.issuance.acme","msg":"done waiting on internal rate limiter","identifiers":["*.skynetfree.net"],"ca":"https://acme-v02.api.letsencrypt.org/directory","account":"devs@siasky.net"}
caddy | {"level":"info","ts":1646175973.8710628,"logger":"tls.issuance.acme","msg":"waiting on internal rate limiter","identifiers":["*.hns.skynetfree.net"],"ca":"https://acme-v02.api.letsencrypt.org/directory","account":"devs@siasky.net"}
caddy | {"level":"info","ts":1646175973.8710725,"logger":"tls.issuance.acme","msg":"done waiting on internal rate limiter","identifiers":["*.hns.skynetfree.net"],"ca":"https://acme-v02.api.letsencrypt.org/directory","account":"devs@siasky.net"}
caddy | {"level":"info","ts":1646175975.0144036,"logger":"tls.issuance.acme.acme_client","msg":"trying to solve challenge","identifier":"skynetfree.net","challenge_type":"dns-01","ca":"https://acme-v02.api.letsencrypt.org/directory"}
caddy | {"level":"info","ts":1646175975.4628952,"logger":"tls.issuance.acme.acme_client","msg":"trying to solve challenge","identifier":"*.skynetfree.net","challenge_type":"dns-01","ca":"https://acme-v02.api.letsencrypt.org/directory"}
caddy | {"level":"info","ts":1646175975.645902,"logger":"tls.issuance.acme.acme_client","msg":"trying to solve challenge","identifier":"*.hns.skynetfree.net","challenge_type":"dns-01","ca":"https://acme-v02.api.letsencrypt.org/directory"}
caddy | {"level":"error","ts":1646176040.616508,"logger":"tls.issuance.acme.acme_client","msg":"cleaning up solver","identifier":"skynetfree.net","challenge_type":"dns-01"}
caddy | {"level":"info","ts":1646176040.6165626,"logger":"tls.issuance.acme.acme_client","msg":"validations succeeded; finalizing order","order":"https://acme-v02.api.letsencrypt.org/acme/order/431842630/68002779550"}
caddy | {"level":"error","ts":1646176041.52123,"logger":"tls.issuance.acme.acme_client","msg":"cleaning up solver","identifier":"*.hns.skynetfree.net","challenge_type":"dns-01"}
caddy | {"level":"info","ts":1646176041.5212748,"logger":"tls.issuance.acme.acme_client","msg":"validations succeeded; finalizing order","order":"https://acme-v02.api.letsencrypt.org/acme/order/431842630/68002781670"}
caddy | {"level":"error","ts":1646176041.5950713,"logger":"tls.issuance.acme.acme_client","msg":"cleaning up solver","identifier":"*.skynetfree.net","challenge_type":"dns-01","error":"no memory of presenting a DNS record for skynetfree.net (probably OK if presenting failed)"}
caddy | {"level":"error","ts":1646176041.774566,"logger":"tls.obtain","msg":"could not get certificate from issuer","identifier":"*.skynetfree.net","issuer":"acme-v02.api.letsencrypt.org-directory","error":"[*.skynetfree.net] solving challenges: presenting for challenge: adding temporary record for zone skynetfree.net.: InvalidChangeBatch: InvalidChangeBatch: [Tried to create resource record set [name='_acme-challenge.skynetfree.net.', type='TXT'] but it already exists]\n\tstatus code: 400, request id: cea7b376-a1b9-4608-b047-3f3c595a374f (order=https://acme-v02.api.letsencrypt.org/acme/order/431842630/68002781280) (ca=https://acme-v02.api.letsencrypt.org/directory)"}
caddy | {"level":"error","ts":1646176041.774632,"logger":"tls.obtain","msg":"will retry","error":"[*.skynetfree.net] Obtain: [*.skynetfree.net] solving challenges: presenting for challenge: adding temporary record for zone skynetfree.net.: InvalidChangeBatch: InvalidChangeBatch: [Tried to create resource record set [name='_acme-challenge.skynetfree.net.', type='TXT'] but it already exists]\n\tstatus code: 400, request id: cea7b376-a1b9-4608-b047-3f3c595a374f (order=https://acme-v02.api.letsencrypt.org/acme/order/431842630/68002781280) (ca=https://acme-v02.api.letsencrypt.org/directory)","attempt":1,"retrying_in":60,"elapsed":67.90433396,"max_duration":2592000}
caddy | {"level":"info","ts":1646176041.779712,"logger":"tls.issuance.acme.acme_client","msg":"successfully downloaded available certificate chains","count":2,"first_url":"https://acme-v02.api.letsencrypt.org/acme/cert/0310ab580c2243e63ffdaa7b9e5a046e2670"}
caddy | {"level":"info","ts":1646176041.7803743,"logger":"tls.obtain","msg":"certificate obtained successfully","identifier":"skynetfree.net"}
caddy | {"level":"info","ts":1646176041.7803993,"logger":"tls.obtain","msg":"releasing lock","identifier":"skynetfree.net"}
caddy | {"level":"info","ts":1646176042.7881117,"logger":"tls.issuance.acme.acme_client","msg":"successfully downloaded available certificate chains","count":2,"first_url":"https://acme-v02.api.letsencrypt.org/acme/cert/04a677ac9b9824f7d0316e4791639a0ac79e"}
caddy | {"level":"info","ts":1646176042.7889297,"logger":"tls.obtain","msg":"certificate obtained successfully","identifier":"*.hns.skynetfree.net"}
caddy | {"level":"info","ts":1646176042.7889636,"logger":"tls.obtain","msg":"releasing lock","identifier":"*.hns.skynetfree.net"}
caddy | {"level":"info","ts":1646176103.1420152,"logger":"tls.issuance.acme.acme_client","msg":"trying to solve challenge","identifier":"*.skynetfree.net","challenge_type":"dns-01","ca":"https://acme-staging-v02.api.letsencrypt.org/directory"}
caddy | {"level":"error","ts":1646176103.6177459,"logger":"tls.issuance.acme.acme_client","msg":"cleaning up solver","identifier":"*.skynetfree.net","challenge_type":"dns-01","error":"no memory of presenting a DNS record for skynetfree.net (probably OK if presenting failed)"}
caddy | {"level":"error","ts":1646176103.7966042,"logger":"tls.obtain","msg":"could not get certificate from issuer","identifier":"*.skynetfree.net","issuer":"acme-v02.api.letsencrypt.org-directory","error":"[*.skynetfree.net] solving challenges: presenting for challenge: adding temporary record for zone skynetfree.net.: InvalidChangeBatch: InvalidChangeBatch: [Tried to create resource record set [name='_acme-challenge.skynetfree.net.', type='TXT'] but it already exists]\n\tstatus code: 400, request id: 760f84f8-7da6-4f89-9f47-302c2098f240 (order=https://acme-staging-v02.api.letsencrypt.org/acme/order/45741628/1916393478) (ca=https://acme-staging-v02.api.letsencrypt.org/directory)"}
caddy | {"level":"error","ts":1646176103.7966654,"logger":"tls.obtain","msg":"will retry","error":"[*.skynetfree.net] Obtain: [*.skynetfree.net] solving challenges: presenting for challenge: adding temporary record for zone skynetfree.net.: InvalidChangeBatch: InvalidChangeBatch: [Tried to create resource record set [name='_acme-challenge.skynetfree.net.', type='TXT'] but it already exists]\n\tstatus code: 400, request id: 760f84f8-7da6-4f89-9f47-302c2098f240 (order=https://acme-staging-v02.api.letsencrypt.org/acme/order/45741628/1916393478) (ca=https://acme-staging-v02.api.letsencrypt.org/directory)","attempt":2,"retrying_in":120,"elapsed":129.926367323,"max_duration":2592000}
caddy | {"level":"info","ts":1646176224.943264,"logger":"tls.issuance.acme.acme_client","msg":"trying to solve challenge","identifier":"*.skynetfree.net","challenge_type":"dns-01","ca":"https://acme-staging-v02.api.letsencrypt.org/directory"}
caddy | {"level":"error","ts":1646176225.7464094,"logger":"tls.issuance.acme.acme_client","msg":"cleaning up solver","identifier":"*.skynetfree.net","challenge_type":"dns-01","error":"no memory of presenting a DNS record for skynetfree.net (probably OK if presenting failed)"}
caddy | {"level":"error","ts":1646176225.9244406,"logger":"tls.obtain","msg":"could not get certificate from issuer","identifier":"*.skynetfree.net","issuer":"acme-v02.api.letsencrypt.org-directory","error":"[*.skynetfree.net] solving challenges: presenting for challenge: adding temporary record for zone skynetfree.net.: InvalidChangeBatch: InvalidChangeBatch: [Tried to create resource record set [name='_acme-challenge.skynetfree.net.', type='TXT'] but it already exists]\n\tstatus code: 400, request id: f5cbc9fe-b415-4059-8cbd-10bc3b214cb1 (order=https://acme-staging-v02.api.letsencrypt.org/acme/order/45741628/1916410268) (ca=https://acme-staging-v02.api.letsencrypt.org/directory)"}
caddy | {"level":"error","ts":1646176225.9244585,"logger":"tls.obtain","msg":"will retry","error":"[*.skynetfree.net] Obtain: [*.skynetfree.net] solving challenges: presenting for challenge: adding temporary record for zone skynetfree.net.: InvalidChangeBatch: InvalidChangeBatch: [Tried to create resource record set [name='_acme-challenge.skynetfree.net.', type='TXT'] but it already exists]\n\tstatus code: 400, request id: f5cbc9fe-b415-4059-8cbd-10bc3b214cb1 (order=https://acme-staging-v02.api.letsencrypt.org/acme/order/45741628/1916410268) (ca=https://acme-staging-v02.api.letsencrypt.org/directory)","attempt":3,"retrying_in":120,"elapsed":252.054161198,"max_duration":2592000}
caddy | {"level":"info","ts":1646176346.8539615,"logger":"tls.issuance.acme.acme_client","msg":"trying to solve challenge","identifier":"*.skynetfree.net","challenge_type":"dns-01","ca":"https://acme-staging-v02.api.letsencrypt.org/directory"}
caddy | {"level":"error","ts":1646176347.6377158,"logger":"tls.issuance.acme.acme_client","msg":"cleaning up solver","identifier":"*.skynetfree.net","challenge_type":"dns-01","error":"no memory of presenting a DNS record for skynetfree.net (probably OK if presenting failed)"}
caddy | {"level":"error","ts":1646176347.9910886,"logger":"tls.obtain","msg":"could not get certificate from issuer","identifier":"*.skynetfree.net","issuer":"acme-v02.api.letsencrypt.org-directory","error":"[*.skynetfree.net] solving challenges: presenting for challenge: adding temporary record for zone skynetfree.net.: InvalidChangeBatch: InvalidChangeBatch: [Tried to create resource record set [name='_acme-challenge.skynetfree.net.', type='TXT'] but it already exists]\n\tstatus code: 400, request id: 519afad6-14c3-4e84-bbd6-66a50dc161c4 (order=https://acme-staging-v02.api.letsencrypt.org/acme/order/45741628/1916424408) (ca=https://acme-staging-v02.api.letsencrypt.org/directory)"}
caddy | {"level":"error","ts":1646176347.991109,"logger":"tls.obtain","msg":"will retry","error":"[*.skynetfree.net] Obtain: [*.skynetfree.net] solving challenges: presenting for challenge: adding temporary record for zone skynetfree.net.: InvalidChangeBatch: InvalidChangeBatch: [Tried to create resource record set [name='_acme-challenge.skynetfree.net.', type='TXT'] but it already exists]\n\tstatus code: 400, request id: 519afad6-14c3-4e84-bbd6-66a50dc161c4 (order=https://acme-staging-v02.api.letsencrypt.org/acme/order/45741628/1916424408) (ca=https://acme-staging-v02.api.letsencrypt.org/directory)","attempt":4,"retrying_in":300,"elapsed":374.120811071,"max_duration":2592000}
I always end up with dangling records:
I cleared all records in aws and restarted caddy. Didn’t help.
