I have an SPA with django as API backend.
My problem is that i have 3 different sources of static files with following structure and I build them from different docker volumes which I can’t properly combine in one folder.
tree /var/www/django/
/var/www/django/
├── dist
│ ├── index.html
│ ├── main.406ac75403562d145b5f.js
│ ├── styles.194bf91866fc202ae066.css
├── media
│ ├── events
│ │ └── 1
│ └── tournaments
│ └── 1
└── static
├── admin
│ ├── css
│ │ └── autocomplete.781713f30664.css
│ └── js
│ ├── urlify.js
│ └── vendor
│ └── jquery
│ └── jquery.min.js
└── staticfiles.json
I need to serve files from /static, /media and /dist folders.
I tried:
- Set root to parent folder /var/www/django, proxy all requests to django and rewrite domain access to dist/index.html. Doesn’t work because seems that caddy (or my mistake somewhere) redirected.
tls {$EMAIL}
header / Strict-Transport-Security "max-age=31536000;"
root /var/www/django
rewrite {
if {path} is /
to /var/www/django/dist/index.html
proxy / web:8000 {
except /static /media /dist
- Proxy only api and admin requests to django, set parent root to /dist folder and rewrite /static and /media requests. Do not understand why does’n work. In caddy logs there is line -
"GET /static/admin/css/base.a419cbad388f.css HTTP/1.1" 404
But in browser there is a problem with MIME type -Refused to apply style from 'https://{DOMAIN_NAME}/static/admin/css/base.a419cbad388f.css' because its MIME type ('text/plain') is not a supported stylesheet MIME type, and strict MIME checking is enabled.
{$DOMAIN_NAME} {
tls {$EMAIL}
root /var/www/django/dist
mime .css text/css # this line does not help also
#rewrite { either this
# if {path} starts_with /static
# if {path} starts_with /media
# to /var/www/django{path}
# or this two blocks
rewrite /static {
r (.*)
to /var/www/django/static/{1}
rewrite /media {
r (.*)
to /var/www/django/media/{1}
proxy /api web:8000 {
proxy /admin web:8000 {
In the end, I can’t figure out how to serve this properly.
