Hi! I try to set up a reverse proxy to the server which runs on a host machine with the address 172.17.0.1:8385
. IP address of the service was selected intentionally to match the IP of docker0
and host.docker.internal
. The service is reachable from the host. However, the reverse proxy does not work and results in the 502 error.
caddy_reverse_proxy | {"level":"error","ts":1691255735.0020468,"logger":"http.log.error.log1","msg":"dial tcp 172.17.0.1:8385: i/o timeout","request":{"remote_ip":"MY_REMOTE_IP","remote_port":"33830","client_ip":"CLIENT_IP","proto":"HTTP/2.0","method":"GET","host":"example.org","uri":"/","headers":{"User-Agent":["Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/113.0.0.0 Safari/537.36"],"Sec-Fetch-Mode":["navigate"],"Sec-Fetch-User":["?1"],"Accept-Encoding":["gzip, deflate, br"],"Sec-Ch-Ua-Mobile":["?0"],"Sec-Ch-Ua-Platform":["\"Linux\""],"Sec-Gpc":["1"],"Cache-Control":["max-age=0"],"Accept":["text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,image/apng,*/*;q=0.8"],"Sec-Fetch-Site":["cross-site"],"Sec-Fetch-Dest":["document"],"Sec-Ch-Ua":["\"Brave\";v=\"113\", \"Chromium\";v=\"113\", \"Not-A.Brand\";v=\"24\""],"Upgrade-Insecure-Requests":["1"],"Accept-Language":["en-US,en;q=0.9"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"example.org"}},"duration":3.001929959,"status":502,"err_id":"gq02k5326","err_trace":"reverseproxy.statusError (reverseproxy.go:1246)"}
v2.7.2
Docker compose
Docker version 24.0.5, build ced0996
Ubuntu 22.04.2 LTS aarch64.
docker compose up -d
version: '3'
services: caddy:
image: caddy:latest
container_name: caddy_reverse_proxy
restart: always
- 443:443
user: ${UID}:${GID}
- ./caddy-config:/config
- ./caddy-data:/data
- vaultwarden # I use it for the reverse-proxy to vaultwarden docker container, and it works fine
extra_hosts:
- "host.docker.internal:host-gateway"
env_file:
- docker-compose.env
vaultwarden:
external: true # I use it for the reverse-proxy to vaultwarden docker container, and it works fine
example.org {
level DEBUG
format console
reverse_proxy host.docker.internal:8385 {
